How to change the CUCM admin page idle logout time
Aug 21st, 2009
Can you change the CUCM administration page idle logout time? If so, how? I'm working on this is a lab and every time I step away to do something, I have to log back in. Can I increase the time for automatic logout? This is CUCM 6.0.1. Thanks.
Overall Rating: 4.5 (2 ratings)
Jaime Valencia Fri, 08/21/2009 - 11:46
No, you can't.
It's fixed at 30 minutes
This has been asked before, please search NetPro for answers.
java
if this helps, please rate
d.anthony.hadley_2 Mon, 08/24/2009 - 04:08
Thanks. I was afraid that might be the answer. I did search this before posting. Maybe I was using the wrong keywords. I used CUCM unified communications manager 6.0 administration page idle timeout logout. Any others I could have used for future reference? Thanks.
Jaime Valencia Mon, 08/24/2009 - 05:30
Way too many words, use less words but use keywords.
You should have tried: ccmadmin + timeout
The same for any future question you might have, use just 2-3 keywords, if you try such complex searches there are very low chances you'll get a hit.
java
rogerholdman Wed, 01/11/2017 - 14:40
I know this may not be for v6 but works on 11
show cli session timeout set cli session timeout <min> show webapp session timeout set webapp session timeout <min>
