Custom Attributes in Custom Inventory Report
Aug 21st, 2009
Hi, I am trying to create a custom report in ciscworks RME 4.0.5. I have created the report with the built-in attributes however i need to add a custom attribute to it which is the software image name. Surprisingly I cannot find it if this attribute is built-in. Strange thing is that if i create a normal built-in software report this attribute does show up so it must be there somewhere however cannot add it to a custom report. Is there any way to add custom attributes to a custom report and if so how would it be done. I am not a cisco works user so would really appreciate detailed instructions. Thx
Joe Clarke Fri, 08/21/2009 - 11:17
No, this is not possible. Unfortunately, not all of the available inventory attributes were made available in the custom inventory templates. I filed CSCsj78780 to get this fixed, and many more attributes were added in LMS 3.1 (RME 4.2). You can now select Image:Image or Image:System Image File from the list of available attributes.
