paolo bevilacqua Fri, 08/21/2009 - 13:11
  • Hall of Fame,
    Founding Member
And what problem does this causes to you ?
mfoyster11 Fri, 08/21/2009 - 13:18
Hello: it is a little aggravating not being able to see were you are without the numbers foolowing the prompt
paolo bevilacqua Fri, 08/21/2009 - 13:20
  • Hall of Fame,
    Founding Member
Thing is router do not normally operate in rommon so not an big issue. Try "sync" anyway.
mfoyster11 Fri, 08/21/2009 - 13:30
Hello: Yes you are right, maybe you could help me im trying to boot this 8540 router from tftp to get ios on flash ram or flash card i have the ios i lost previos 8540 in a fire i have other 8540's and new flash card but not cisco card if i can boot from tftp and the copy to flash ram great or flash card is there any utilitys for flash card in the pcmcia in computer to format card
paolo bevilacqua Fri, 08/21/2009 - 13:38
  • Hall of Fame,
    Founding Member
Try "tftpboot" it will tell you the commands you have to enter in order to do that.
