problem accessing webserver
Aug 22nd, 2009
Hi all, I have a problem with pix 515e version 8.0(3) with asdm 6.0(3), I can't access to following sites www.rsp-informatica and http://www.jspires.com I notice that both sites are store in the same server (70.87.32.131), this server is a webhosting ip address.
I can't access to any website store in this server, when I tried to access to any of this websites I get the following error in the pix real-time log viewer.
Severity Date Time Syslog ID Source IP Destination IP Description
3 xxxx xxxx 305006 70.87.32.131 Portmap translation creation failed for
tcp src inside:10.0.0.21/50076 dst inside:
70.87.32.131/80
10.0.0.21 is the address from the workstation I am using, I can't access to this server from any address from my inside network.
the attachment contais pix configuration, thank you so much in advance and I will be looking forward for any information that help me solve this problem.
Jon Marshall Sat, 08/22/2009 - 04:19
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jose
Not sure what the following 2 lines are doing -
static (outside,outside) tcp interface www 70.87.32.131 www netmask 255.255.255.255 dns
access-list gatedefender extended permit tcp host 70.87.32.131 any eq www
if the web sites are just like any other web site on the Internet then the above lines shouldn't be needed.
Jon
j-baptistamartins Sat, 08/22/2009 - 11:18
hi jon, first thank you for your reply , the lines you are refering where add after i detected the problem, it was an Attemptt to trie to fix it.
I already remove both lines.
But i stil remain with problem.
