Route maps: Multiple set extcommunity rt for one match
Aug 22nd, 2009
Dear friends,
Is it possible to have multiple set extcommunity rt's for one match statement.
The reason being that i want to leak routes from one PE to another but i have to leak the same routes (in match clause) to more than one vrf. Thats the reason i feel the need for multiple set extcommunity rt's for a single match clause.
Wouter Prins Sun, 08/23/2009 - 03:52
Hello gautamzone,
This set statement of the route-map should do what you want:
match x
set extcommunity rt 65001:1 65001:2 additive
The additive keyword is set so the current communities are still present.
HTH,
Wouter
