520 Express switch, max number of VLANs allowed ?
Aug 23rd, 2009
Hi, helping a friend set up a network using 3750 as the core and 520 Express as remote switches ( 24 LC versions )
Reading cisco own documentation on the web it suggests that upto 32 Vlans can be configured on the 520's, see link :
On the Layer 2 details it specifies "Upto 32 VLANs".
But using CCA I am only about to configure 16 before I get the "maximum vlans" error message ?
My friend requires more than this and is hoping this is not the limit !!
Any advice appreciated.
Lucien Avramov Sun, 08/23/2009 - 08:19
The maximum number of VLANs allowed for UC500 is 15.
If you go on the command line and try to create a vlan, it should not work either.
The documentation is wrong, to fix it, we will need a TAC case.
