CAC bandwidth allocation
Aug 23rd, 2009
Can someone please summerize the bandwidth allocation done by ccm and gatekeeper?
[assume we are using latest versions/spec.]
Is it true that both CCM(CAC) and Gatekeeper allocate twice the amount of codec bit rate for admission request?
For example ccm/gk reserves 128kbps bw for a G.711 call request to accomodate bi-directional voice stream. And without reserving bw for overheads. Is that true?
Overall Rating: 4.5 (2 ratings)
Jaime Valencia Sun, 08/23/2009 - 11:39
  • Cisco Employee,
  • Hall of Fame,
    2011
No, CUCM considers (RTP + overhead)x2. GK only RTP x 2
Location Configuration
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_1_2/ccmcfg/b02locat.html
For purposes of location bandwidth calculations only, assume that each call stream consumes the following amount of bandwidth:
•G.711 call uses 80 kb/s.
•G.722 call uses 80 kb/s.
•G.723 call uses 24 kb/s.
•G.728 call uses 16 kb/s.
•G.729 call uses 24 kb/s.
•GSM call uses 29 kb/s.
•Wideband call uses 272 kb/s.
Note Each call comprises two call streams.
IE with G711 for 1 call
CUCM = 160
GK = 128
G729
CUCM = 48
GK = 16
java
if this helps, please rate
