WAN problem
Aug 23rd, 2009
I have a problem with my Internet connection a the link is flapping up and down. Below is the configuration that i have on the router and the errors that i am getting:
Current configuration : 2589 bytes
version 12.4
service password-encryption
hostname RTR1
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
ip cef
ip domain name yourdomain.com
vpdn enable
interface FastEthernet0/0
description **FROM_ASA**
ip address 10.x.x.x 255.255.255.248
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1
description WAN Interface
no ip address
no ip unreachables
ip nat outside
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface Serial0/1/0
no ip address
shutdown
clock rate 2000000
interface Dialer1
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname iatadmn
ppp chap password 7 xxxxxx
ppp pap sent-username iatadmn password 7 xxxxx
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 10.0.0.0 255.0.0.0 10.7.221.5
ip http server
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer1 overload
access-list 1 permit 10.0.0.0 0.255.255.255
access-list 101 permit ip 10.7.0.0 0.0.255.255 any
access-list 101 permit ip 10.8.0.0 0.0.255.255 any
control-plane
line con 0
logging synchronous
login local
line aux 0
line vty 0 4
privilege level 15
logging synchronous
login local
transport input telnet
line vty 5 15
privilege level 15
logging synchronous
login local
line vty 16 807
logging synchronous
login local
scheduler allocate 20000 1000
end
The errors are the following:
611: %DIALER-6-BIND: Interface Vi1 bound to profile Di1
*Aug 23 10:49:24.615: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to upterface Virtual-Access1, changed state to up
*Aug 23 07:47:22.763: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down
*Aug 23 07:47:45.851: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
*Aug 23 07:48:48.939: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down
.675: %LINK-3-UPDOWN: Interface Dialer1, changed state to up
Mohamed Sobair Sun, 08/23/2009 - 10:47
  • Gold, 750 points or more
You dont need natting outside on Fastethernet0/1 interface, you already have it on the Dialer Interface.
Check the link between your ADSl modem and Fastethernet0/1 , flapping here should result in flapping on the dialler as well.
Mohamed
slmansfield Tue, 08/25/2009 - 07:36
  • Silver, 250 points or more
There are two things I'd look at in your configuration.
I'd make sure the PPP negotiation and authentication is succeeding. I think this is the most likely cause of the flapping if it is not a physical interface problem.
Otherwise, it looks like you have a dialer-group statement under the Dialer1 interface that is not associated with a dialer-list. Perhaps you simply did not include the dialer-list statement in the posted config. The dialer-group causes the Dialer1 interface to come up only if there is interesting traffic, specified by an access list, which is associated with a dialer-list. The dialer-group/dialer-list combination is usually used in a Dial-on-demand situation. If that is not your intent, I'd remove the dialer-group statement.
