CISCO ASA 5520 configuration problems
Aug 23rd, 2009
Guys I'm stuck and need as much help as possible please. I'm from Guyana, South America. I have my ISP connected to one cisco 2800 series Router connected to a Cisco ASA 5520 firewall then to a dell power connect switch then 9 small networks on Cisco 881 Routers. Also from the ASA 5520 I have my servers connected as DMZ. Now What I want to accomplish is for my DMZ to have outbound and inbound access to the internet and my small networks to reach the DMZ and also the internet. Also VPN from remote networks to access the DMZ. below is my current running-config on the ASA 5520.
ASA Version 7.2(4)
domain-name GPF.LOCAL
enable password
passwd encrypted
interface GigabitEthernet0/0
nameif OUTSIDE
security-level 0
ip address
interface GigabitEthernet0/1
nameif INSIDE
security-level 100
ip address
interface GigabitEthernet0/2
nameif DMZ
security-level 50
ip address
interface GigabitEthernet0/3
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
ip address
ftp mode passive
dns server-group DefaultDNS
same-security-traffic permit intra-interface
object-group protocol ip-allow
protocol-object ip
protocol-object icmp
protocol-object udp
protocol-object tcp
access-list OUTSIDE_access_in extended permit object-group ip-allow any
access-list OUTSIDE_access_in extended permit tcp any
access-list INSIDE_access_out extended permit ip any any
access-list DMZ_access_out extended permit ip any any
access-list OUTSIDE_1_cryptomap extended permit ip
access-list INSIDE_nat0_outbound extended permit ip
access-list allow_outside_connections extended permit icmp any any echo-reply
access-list allow_outside_connections extended permit icmp any any source-quench
access-list allow_outside_connections extended permit icmp any any unreachable
access-list allow_outside_connections extended permit icmp any any time-exceeded
pager lines 24
logging enable
logging asdm informational
mtu OUTSIDE 1500
mtu INSIDE 1500
mtu DMZ 1500
mtu management 1500
no failover
monitor-interface OUTSIDE
monitor-interface INSIDE
monitor-interface DMZ
monitor-interface management
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-524.bin
no asdm history enable
arp timeout 14400
global (OUTSIDE) 101 netmask
global (OUTSIDE) 200 interface
global (INSIDE) 1 netmask
global (DMZ) 1 netmask
nat (INSIDE) 0 access-list INSIDE_nat0_outbound
nat (INSIDE) 1
nat (INSIDE) 101
nat (DMZ) 1 outside
access-group OUTSIDE_access_in in interface OUTSIDE
access-group INSIDE_access_out out interface INSIDE
access-group DMZ_access_out out interface DMZ
route OUTSIDE 1
route INSIDE 1
route DMZ 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
http server enable
http management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
mark.stclaire Mon, 08/24/2009 - 08:30
hey Josh! thanks so far, I'm off to a running start. However I still have some issues.
I might be able to help you with part of your problem. I had a similar situation on my network the other day.
If you check your logs after one of your small networks tries to access the DMZ you might see an error about not having a translation group. I am not sure if this is the correct way of doing it but it worked for me.
You need a STATIC statement for the ASA to pass traffic from the LAN > DMZ and vice versa, without it trying to NAT. So your statement would look something like this:
STATIC (inside,DMZ) netmask
if your ACLs are correct then this should work. Like I said before though, I am not sure if this is the correct and secure way of doing it, but I know this worked for me.
