EoMPLS with different vlans at the ends
Aug 23rd, 2009
Hi guys,
It's possible configure different vlan between CE1-PE1 and CE2-PE2? x example:
CE ip=10.0.0.1 (vlan 5) === PE --MPLS--PE== (vlan 10) ip= 10.0.0.2 CE
It's correct? or exist problem with the configuration?, currently i'm simulating with dynamips and work fine.
Please could be validate the scenario?
Thx in advance!.
Overall Rating: 3 (1 ratings)
amit.bhagat Sun, 08/23/2009 - 18:40
Hi Henrry,
EoMPLS can run in two modes- Ethernet Port mode or Ethernet VLAN mode.
In Ethernet VLAN mode, the VLAN ID is re-written either on ingress PE or egress PE. Hence, the VLAN IDs do not have to match on each side.
However, when you run EoMPLS in Port mode, the whole trunk is carried across the MPLS network and hence VLAN IDs should match.
You can view the type of mode by doing
show mpls l2transport vc command.
HTH.
Amit.
dmickels Sun, 10/07/2012 - 17:06
  • Cisco Employee,
What about using QinQ over EoMPLS.  Can the "outside" vlan tag be re-written from ingress to egress?  (I'd prefer to leave the "inside" Q-tag along.)
Ashish Panda Fri, 10/12/2012 - 00:34
  • Cisco Employee,
This should be possible
1. in an effeciant and scalable manner With the EVC frame work.
https://supportforums.cisco.com/docs/DOC-21299
2.Stacked VLAN processing (The inner tag cannot be changed in this method)
http://www.cisco.com/en/US/docs/ios/12_0s/feature/guide/qinq.html
Check the restrictions section in the above link.
When you configure an EoMPLS tunnel on stacked  VLAN subinterfaces, the SP-VLAN ID is removed from the frame at the  ingress interface. The remote PE router will add (if required) the  SP-VLAN ID configured on its egress subinterface before forwarding the  frame.
examples
Router(config)# interface gigabitethernet3/0.3
Router(config-subif)# encapsulation dot1q 50 second-dot1q any
Router(config-subif)# xconnect 4.4.4.4 200 encapsulation mpls
Hope this helps.
Ashish
Giuseppe Larosa Sun, 08/23/2009 - 22:48
  • Hall of Fame,
    Founding Member
Hello Henrry,
this is possible with the so called vlan-id rewrite feature.
It should be possible with the appropriate hardware in current IOS release of cisco 12000 or other platforms like C7600
Have a nice week
Hope to help
Giuseppe
jon.harald.bovr... Sun, 08/23/2009 - 23:04
No problem running this in C7200 as well.
But be aware if connecting switches in both ends and running STP across preudowire. Will not work. In your scenario switch in vlan 10 would recieve BPDU containing vlan 5 information. Following an err-disabled situation.
Reason for this is that vlan rewrite feature will rewrite header only, not content of BPDU or other control packets
Fix: No STP or BPDU filter or no switch connected at PE
Jon
henrry.huaman Tue, 12/15/2009 - 14:00
Hi Guys,
For Your Information
We have found the next Bug:
CSCsz14262
In the plataform:
GSR12k  Software release: 12.0(32)SY2
Symptom:
Unable to configure rate-lmit in GE subinterfaces.
Conditions:
GSR running 12.0(32)SY2 with xconnect configured in the subinterface.
shivlu jain Mon, 08/24/2009 - 21:27
  • Silver, 250 points or more
Hi Henrry
The questione asked is very good. Becuase everytime we think that the vlan should be unique in the MPLS cloud while providing EoMPLS services.But the vlans might be different not the vcid. VCID should be unique through the cloud. When the traffic frded by CE1 over vlan 5 and when the frame comes at PE at that time the vlan tag is removed and vcid comes in picture. So you can use the different vlans but vcid should be unique between the PEs.
regards
shivlu jain
amit.bhagat Mon, 08/31/2009 - 18:27
Is there any command in Cisco to disable VLAN tag rewrite for EoMPLS?
I want to see how PE devices communicate in case the VLAN IDs do not match. According to RFC, they use the "Interface Parameters value 0x16" of PW FEC TLV to order the correct VLAN ID.
Please assist.
Amit.
Laurent Aubert Tue, 09/01/2009 - 12:53
  • Cisco Employee,
Hi Amit,
There is no such command.
This optional parameter will be used only when a PE doesn't support VLAN ID rewrite at disposition. It also implies the other PE support VLAN ID rewrite at imposition.
If you want to see it in action, old E2 LC for GSR doesn't support VLAN ID rewrite at disposition. Use an E3 or E5 LC on the other PE.
Laurent.
judebryant Mon, 10/29/2012 - 14:28
if your mpls cloud is 7600 with ES+ cards
you can use
service instance 10 ethernet
encapsulation dotq1 10
rewrite ingress tag translate 1-to-1 dot1q 5
xconnect 4.4.4.4 encapsulation mpls
ASR 9k
interface GigabitEthernet0/0/0/0/3.10 l2transport
encapsulation dot1q 10
 rewrite ingress tag translate 1-to-1 dot1q 5 symmetric
Jude
