Single-#-reach
Answered Question
Aug 23rd, 2009
I have configured remmote profile & added my cell # to it.
My DID in my UDP has proper DID with external mask same as DID.
Now if i call my DID from any other DID condifugured in call manager, it shows my proper caller ID to remote device.
but if someone call from pstn to my DID & when it rings on remote device, it shows my pilot number assigned to my PRI.
Any clue , how to make proper CLI (i.e. to remote device)
Correct Answer by gogasca about 7 years 8 months ago
Hi sir,
You may need to check with your Provider to see if they will mask unknown numbers coming from your PRI. (i.e, you call from random phone # 408-111-2222 to your DID 408-111-3333, this is CFA to your cell phone 408-111-4444)
In your cell phone you should see call from 408-111-2222, but Telco switch overwrites this info since this range is not assigned to your Trunk (3333 range).
You can check debugs if CUCM/PSTN GW is sending proper calling number.
Overall Rating: 5 (1 ratings)
Correct Answer
gogasca Tue, 08/25/2009 - 19:15
  • Green, 3000 points or more
Hi sir,
