7613 atm card failure
Answered Question
Aug 24th, 2009
I have a 7613 router with image "c7600rsp72043-adventerprisek9-mz.122-33.SRD2.bin" but my router cannot enable my SPA-4XOC3-ATM. I am getting this message "SPA-4XOC3-ATM card in subslot 1/0 is being disabled because of an incompatible FPD
image version. Note that the c7600-fpd-pkg.122-33.SRD2.pkg package will be required if you want to perform the upgrade operation". My problem here is how do I check the version before downloading the ios required? this is a new router and the ios that is on this router is the latest IOS.
Correct Answer by Giuseppe Larosa about 7 years 10 months ago
Hello Mpho,
my understanding is that the device is asking you to upgrade the firmware (FPD) of the SPA using the specified file:
So you should download this file that is not an ios image from cisco site and you should put it on the flash.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Mon, 08/24/2009 - 01:13
  • Hall of Fame,
    Founding Member
Hello Mpho,
Hope to help
Giuseppe
