MAC learning from local instead of device.
Aug 24th, 2009
Hi all,
I have found the below error log in my switch 4507.
Aug 24 10:22:32.453: (Suppressed 21 times)Packet received with my own MAC address (00:19:06:D0:D5:FF) as source on port Gi3/37 in vlan 64
I cleared the MAC table as suggested in the cisco web but still the same error is coming
What will cause with this error if continue?
What can be done to stope this?
Experts please help me to stop this....
Naidu.
ktwaddell Mon, 08/24/2009 - 04:27
Can you do the following commands
sh cdp ne g3/37 de
sh runn int g3/37
sh int status (just copy the g3/37 bit)
Kev
ilnaiduccna Mon, 08/24/2009 - 05:40
Hi Kev,
Thanks for the early reply, Please find the below details.
4507#sh cdp neig gigabitEthernet 3/37 detail
4507#sh run int gi3/37
Building configuration...
Current configuration : 127 bytes
interface GigabitEthernet3/37
description Sev1 is Connected to storage Expansion
switchport access vlan 64
end
4507# sh int status
Gi3/37 Sev1 is Connected t connected 64 a-full a-100 10/100/1000-TX
Naidu.
ktwaddell Mon, 08/24/2009 - 05:50
The device that is connected to g3/37 (storage Expansion is it?) does it have more than 1 nic connected?
Kev
ilnaiduccna Tue, 08/25/2009 - 23:05
Hi Kev,
I got the below information from Cisco.
They are saying... Check the switch configuration file to determine the source of these packets on the specified port and take corrective action to fix them at the source
And force the switch to re-learn the MAC addresses correctly
Can you please tell me what configuration i need to check to force the switch to learn correct MAC address.
Problem
The switch reports the %C4K_L2MAN-5-ROUTERMACADDRESSRXASSOURCE:Packet received with my own MAC address ( [mac-addr] ) as source on port [char] in vlan [dec] error message.
Cause
A packet was received with the MAC address of the switch as the source address. This MAC was not learned as a valid source address, which suggests that there is a configuration problem. This message is rate-limited and is displayed only for the first such packet received on any interface or VLAN. Subsequent messages display a cumulative count of all such packets received in a given interval on all interfaces in any VLAN.
Solution
Complete these steps to resolve the issue:
Clear the MAC address table and force the switch to re-learn the MAC addresses correctly.
Switch#clear mac-address-table dynamic
Check the switch configuration file to determine the source of these packets on the specified port and take corrective action to fix them at the source. This usually signifies a loop in your configuration.
ilnaiduccna Tue, 08/25/2009 - 23:50
Hi Kev,
I got that the device connected in to this port (gi3/37) is one of the SAN switch.
Naidu.
ilnaiduccna Wed, 08/26/2009 - 21:53
Hi All,
Can any someone please help me on this.
one of the SAN switch connected in port gi3/37.
Naidu.
Latchum Naidu Tue, 03/09/2010 - 01:25
Hi Kev,
Please find the below log message:
057352: Mar  3 07:58:18.210: (Suppressed 1062 times)Packet received with my own MAC address (00:19:06:D0:D5:FF) as source on port Gi3/37 in vlan 64
057333: Mar  2 13:50:14.153: (Suppressed 1078 times)Packet received with my own MAC address (00:19:06:D0:D5:FF) as source on port Gi3/38 in vlan 64
Yes, Storage systems connected on this port
description A14 is Connected to IBM system storage Expansion
switchport mode access
interface GigabitEthernet3/38
description A15 is Connected to IBM DS4700 System storage
Can some one let me know will it cause any issues in real time as it is production envi and how I can avoid these messages.
