AA script with redirect to voicemail
Answered Question
Aug 24th, 2009
Hi all, there is a way in a AA script to send caller in a specific voicemail? If yes how?
Thanks Enrico
Correct Answer by Brandon Buffin about 7 years 10 months ago
The following link explains how to do this. The versions are different, but the concept remains the same.
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_tech_note09186a00802ab979.shtml#cue_int_ccm
Hope this helps.
Brandon
Overall Rating: 5 (1 ratings)
Brandon Buffin Mon, 08/24/2009 - 06:13
  • Purple, 4500 points or more
Callmanager or Callmanager Express? Version? What is providing the AA? Unity? Unity Express? Version?
Brandon
epasqualotto Mon, 08/24/2009 - 06:22
CallManager 5.1.3 and CUE 2.3.4
The script check for holidays and business hours and send calls to operator or prompt+voicemail if out of work hour.
