WAE-612 does't recognise disks in 0/0
Aug 24th, 2009
  • Bronze, 100 points or more
I purchased a WAE-612 with ACNS software, but it doesn't recognize any disk i put in slot 0, box0.
In fact, the bios boot gives me:
Slot Box Dev SAS Address Vendor Model Rev Size
0 00 0 FFFFFFFFFFFFFFFF Disk Error
1 01 1 500000E01F667231 IBM-ESXSMBA3300RC SA05 279.39 GB
7F 01 2 5005076C05C314CE IBM SAS SES-2 DEVICE 1.11
if i swap slot 1 disk with slot 0 -> the same. it doesn't seem to recognize any disk in slot 0.
DOA replacement ?
PS. I tried option 7 using recoevery cd , didn't work
i tried "disk recover" command, didn't work
dstolt Tue, 08/25/2009 - 10:11
  • Cisco Employee,
You could look internally to make sure the cables are secure. I would then recommend you RMA the unit, the controller or internal connections may be faulty.
Hope that helps,
Dan
Daniel Laden Sun, 08/30/2009 - 23:24
  • Cisco Employee,
If you have done the troubleshooting to show the problem follows the slot and not the disks, you will want to proceed with a DOA RMA.
- Dan
