Tracert Timeouts
Answered Question
Aug 24th, 2009
Hi all,
Can you help me determine why I am getting timeouts on my tracert tests. Essentially I get a response from my gateway, and the next hop after (edge router, but then I get nothing after that. The next hope would be a router administrated by our umbrella organization - but here is the unsual part, I eventually do receive the last or destination hop back.
So a tracert to yahoo looks like this:
1 <1 ms <1 ms <1 ms 10.4.4.2
2 * * * Request timed out.
3 * * * Request timed out.
4 * * * Request timed out.
5 * * * Request timed out.
6 * * * Request timed out.
7 * * * Request timed out.
8 * * * Request timed out.
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 22 ms 20 ms 21 ms 69.147.76.15
A tracert to my Edge Router looks like this:
C:\Documents and Settings\deckard>tracert 164.106.71.1
Tracing route to 164.106.71.1 over a maximum of 30 hops
2 1 ms 1 ms 1 ms 153.109.69.1
Trace complete.
A tracert to the next hop router (admined by our umbrella organization) looks like this:
C:\Documents and Settings\deckard>tracert 153.109.1.1
Tracing route to ns1.cc.va.us [153.109.1.1]
over a maximum of 30 hops:
1 <1 ms 1 ms <1 ms 10.4.4.2
5 13 ms 12 ms 13 ms blah.blah.blah [153.109.1.1]
Trace complete.
Am I correct in saying that the return traffic is being blocked by our parent company (153.109.1.1)?
Correct Answer by Joe Clarke about 7 years 10 months ago
Tracert works using ICMP. It sends an ICMP echo request with a low TTL number to find each hope along the path. Intermediate hops should reply with an ICMP time exceeded message where as the final destination should reply with an ICMP echo reply. It could be that the intermediate gateways are not sending back or blocking the time exceeded message (type 11, code 0), but allowing echo reply (type 0, code 0).
A lot of firewalls allow time exceeded in, but do not permit it out.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Mon, 08/24/2009 - 07:21
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
oneirishpollack Mon, 08/24/2009 - 07:31
Thanks for your help. I shamefully admit that I was blocking the Time Exceeded packets from coming into my network.
Problem solved.
Are there any major DOS attacks I expose myself to by leaving it open?
Thanks, again.
Joe Clarke Mon, 08/24/2009 - 07:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I allow type 11 in (in addition to types 0, 3, and 4). This message is typically safe.
