Updating Startup-config ASA5505
Answered Question
Aug 24th, 2009
Is is possible to edit and update the startup-config on an ASA5505 remotely.
I need to change the IP & default gateway remotely prior to a switch over of ISP. I had hoped to edit the startup before it changed but it doesn't seem possible.
Correct Answer by suschoud about 7 years 5 months ago
try THIS :
copy the existing running config to a tftp server.
copy run tftp
change the ip and d.g. in the running config file on tftp server.
copy the same file to startup
copy tftp start
Once ASA is rebooted,it would come back up with changed settings.
Plz rate if helps.
Sushil
Overall Rating: 5 (1 ratings)
Correct Answer
suschoud Mon, 08/24/2009 - 16:55
try THIS :
copy run tftp
copy tftp start
Plz rate if helps.
Sushil
