Radius dropping from Wlan for 1 minute then re-connecting
Aug 24th, 2009
I keep getting this message during my day and can't seem to find the problem:
WCS has detected one or more alarms of category Switch and severity Major in Virtual Domain root
for the following items:
Radius server ''(port 1812) is deactivated on WLAN 'loyola'. (2 times)
Radius server ''(port 1812) is deactivated on WLAN 'loyola'. (3 times)
E-mail will be suppressed up to 30 minutes for these alarms.
I checked with the server people and they are not seeing any droppage(if that's a word), but My users do see a bit of a blip. Any ideas of what may be happening? Is there some timer I'm missing that might be causing this? I checked the passwords, we are using 1812 for authentication so, not sure where to turn.
Thanks in advance for any help..
kristoferheyl Tue, 08/25/2009 - 22:58
Do you have multiple RADIUS servers on your network?
I'm having a similar problem, RADIUS #1 is deactivated and RADIUS #2 is activated. And then vice versa.
I think I have come to this conclusion: I'm seeing in RADIUS logs that a client is failing authentication multiple times. WLC then "toggles" over from RADIUS #1 to RADIUS #2 and tries authentication. (Therefore - RADIUS #1 is deactivated) This only occurs when a client is failing authentication multiple times (due to incorrect credentials).
Is this issue affecting end users?
Edit: Saw now that users "see a bit of a blip". In more detail, what happens?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
