VG224 SCCP
Aug 24th, 2009
I have a CM7 cluster in which all GW's are H323. I have a requirement to support a VG224, but I do not want to run mgcp, if at all possible. Has anyone used SCCP to control this? Or is MGCP the best way to do this? thanks
Overall Rating: 5 (1 ratings)
Nicholas Matthews Mon, 08/24/2009 - 11:29
  • Red, 2250 points or more
Both SCCP and MGCP are good to run on the VG224. I would say if you're doing a lot of faxing you may want MGCP, but SCCP will offer the most features for the phones.
I would run 12.4(20)T or later for SCCP or MGCP on the VG224, and it should work fine.
-nick
