08-24-2009 12:02 PM - edited 03-15-2019 07:29 PM
Hi All,
I only have 1 of 15 phones registered on SRST mode, my question is how can I force to register again with the CUCM, just plug-out and plug-in or any command on the Voice Gateway...
Thanks in advance
Andres
Solved! Go to Solution.
08-24-2009 12:08 PM
Andres,
One way to force the registration is to reset the phone(s):
router#conf t
router(config)#call-manager-fallback
router(config-cm-fallback)#reset all
Hope this helps.
Brandon
08-24-2009 12:08 PM
Andres,
router#conf t
Hope this helps.
Brandon
08-24-2009 01:36 PM
thankyouverymuch!
Andres
10-17-2018 08:22 AM - edited 10-17-2018 08:38 AM
If the reset doesn't fix your problem the issue could be DNS.
Browse to the phone by putting its IP Address in a web browser.
Look in the configuration settings for the Call Manager Field. Could be named something like Unified CM 1 or Unified CM Primary etc...
If there is a host name for CUCM in this field then the phone will use DNS to resolve that host name.
If the lookup fails the phone will move on to Unified CM 2 and then its SRST Router field which is usually an IP Address.
Fix the DNS problem and your phone should register to CUCM.
