Scheduled time to shutdown LAP
Aug 24th, 2009
Hi, i have WLC running IOS version 6 and bunch of AP (1142N, IOS 12.4(21a)JA) that i would like to shutdown at certain time. Eg. would like to have AP up at 6am and shut down at 7pm. Can this be done on WLC or on the switch where APs are connected to (btw, the switch with APs have poe available)?
Dragan Milojevic Wed, 08/26/2009 - 21:40
Could you pls tell me where is shutdown option located in WCS?
Thanks for a link - will check it out.
scottwilliamson Mon, 09/14/2009 - 07:45
Hi Dragan,
You need to have WCS and WLC v 6.0. Go to configure APs then tick the ones you want to schedule and choose 'Schedule Radio Tasks' from the drop down menu.
Hope this helps
Trending Topics - Security & Network
