Can I connect a 2900XL switch to Cisco 7960 pc port?
Answered Question
Aug 24th, 2009
It doesn't seem to be working. I tried access vlan as well as trunking config on the 2900XL switch port to a 7960 phone PC port.
Correct Answer by paolo bevilacqua about 7 years 9 months ago
Try disabling spanning tree.
Overall Rating: 5 (1 ratings)
paolo bevilacqua Mon, 08/24/2009 - 14:18
  • Hall of Fame,
    Founding Member
Should work. But why don't you connect it upstream of the phone then.
Yang Xia Mon, 08/24/2009 - 14:25
It's a temporary switch and I don't want to mess around the phone upstream connection. Also I can power on/off the 2900 switch without affecting the phone. What should I configure the switch port to 7960 pc port? I've tried both access and trunk mode.
paolo bevilacqua Mon, 08/24/2009 - 14:27
  • Hall of Fame,
    Founding Member
Access. Check, it may get blocked by bpduguard or other security feature.
Yang Xia Mon, 08/24/2009 - 14:44
Access doesn't work. Switch is getting the bpdu packet from the phone pc port.
interface FastEthernet0/1
switchport access vlan 231
end
00:02:03: %SPANTREE-2-RECV_1Q_NON_TRUNK: Received 802.1Q BPDU on non trunk FastEthernet0/1 on vlan 231.
00:02:03: %SPANTREE-2-BLOCK_PORT_TYPE: Blocking FastEthernet0/1 on vlan 231. Inconsistent port type.
Changed to trunk port still doesn't help. Switch thinks it's the root for both VLANs.
switchport mode trunk
end
#sh spanning-tree brief
VLAN1
Spanning tree enabled protocol IEEE
ROOT ID Priority 32768
Address 0001.968f.94c0
This bridge is the root
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32768
Port Designated
Name Port ID Prio Cost Sts Cost Bridge ID Port ID
Fa0/1 128.13 128 19 FWD 0 0001.968f.94c0 128.13
Fa0/4 128.16 128 19 BLK 0 0001.968f.94c0 128.16
Fa0/5 128.17 128 19 BLK 0 0001.968f.94c0 128.17
Fa0/6 128.18 128 19 BLK 0 0001.968f.94c0 128.18
Fa0/7 128.19 128 19 BLK 0 0001.968f.94c0 128.19
Fa0/8 128.20 128 19 BLK 0 0001.968f.94c0 128.20
Fa0/10 128.23 128 19 BLK 0 0001.968f.94c0 128.23
Fa0/11 128.24 128 19 BLK 0 0001.968f.94c0 128.24
Fa0/12 128.25 128 19 BLK 0 0001.968f.94c0 128.25
Fa0/13 128.26 128 19 BLK 0 0001.968f.94c0 128.26
Port Designated
Fa0/14 128.27 128 19 BLK 0 0001.968f.94c0 128.27
Fa0/15 128.28 128 19 BLK 0 0001.968f.94c0 128.28
Fa0/16 128.29 128 19 BLK 0 0001.968f.94c0 128.29
Fa0/17 128.31 128 19 BLK 0 0001.968f.94c0 128.31
Fa0/18 128.32 128 19 BLK 0 0001.968f.94c0 128.32
Fa0/19 128.33 128 19 BLK 0 0001.968f.94c0 128.33
Fa0/20 128.34 128 19 BLK 0 0001.968f.94c0 128.34
Fa0/21 128.35 128 19 BLK 0 0001.968f.94c0 128.35
Fa0/22 128.36 128 19 BLK 0 0001.968f.94c0 128.36
Fa0/23 128.37 128 19 BLK 0 0001.968f.94c0 128.37
Fa0/24 128.38 128 19 BLK 0 0001.968f.94c0 128.38
VLAN231
Address 0001.968f.94c1
Port Designated
Fa0/1 128.13 128 19 FWD 0 0001.968f.94c1 128.13
Fa0/2 128.14 128 19 FWD 0 0001.968f.94c1 128.14
Fa0/3 128.15 128 19 BLK 0 0001.968f.94c1 128.15
Fa0/9 128.22 128 19 FWD 0 0001.968f.94c1 128.22
Correct Answer
paolo bevilacqua Wed, 08/26/2009 - 15:34
  • Hall of Fame,
    Founding Member
Yang Xia Thu, 08/27/2009 - 13:26
That takes care of the issue. Thanks for the tip!
