Translation Pattern CUCM 7.0 - 4 digit to external number
Aug 24th, 2009
Hello All,
I'am trying to configure some translation patterns which translates the 4 digit dialed number to an external number. However when I dial the 4 digits I get a fast busy. the access code is (9.) and normal dialing works.Do I need route patterns without 9., to get this to work?
Jaime Valencia Mon, 08/24/2009 - 17:04
No, translate whatever 4 digit number you want into something that matches a valid route pattern you already have.
Just make sure to use the right CSS for TP.
if this helps, please rate
