Upgrade CCM from 5.1(3) to 7.1
Aug 24th, 2009
Dear all !
I have a plan to upgrade CCM form 5.1(3) to 7.1. After checking the compatibility matrix for Software and hardware, I found my CCM can upgrade to 7.1. However, I can not find the Part Number to upgrade from 5.1(3) to 7.1. only form 6.x to 7.x is available.
Can anyone know which is the part-number to upgrade from 5.1 to 7.1 ???
Chidd
nihdas Tue, 08/25/2009 - 01:42
Can you please send me any doc which says about the compatibility matrix for Software and hardware?
Nihar
Rob Huffman Tue, 08/25/2009 - 04:32
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Nihar,
This is the "master" list for Server support;
Supported Cisco Unified Communications Manager Releases by Server
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
For more information about supported Cisco Unified CM upgrades, see the Cisco Unified Communications Manager Software Compatibility Matrix at the following URL:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html
Hope this helps!
Rob
chidd Tue, 08/25/2009 - 21:19
I am still waiting for part number which used to upgarde form 5.1 to 7.1. Can anyone help ???
Chidd
