Cannot install My VPN_3.0 in my system.
Aug 24th, 2009
I cannot install my Vmsiexec /passive /i "VDI_3.msi" REBOOT=ReallySuppressN in my system, at the time of installation the fist execution finishes and the second execution runs upto 60% and 2 Icon aappear on the desktop in square size and then the screen blinks and then run upto 100% and gets back to 1 and the 2 icons from the desktop disappears.This procedure is done at Command Promp.
if the same process is executed by clicking the setup file from the main screen it goes to next & next at the end it shows a msg " Determistic Network Enhancer require a re-boot first and reinstall
