SIP + NAT
Aug 24th, 2009
I have IP PBX, NAT router (cisco) and SIP-phone connected as follows:
IP PBX<-internet->NAT router<-LAN->SIP phone
The problem: When I make a call from SIP phone to IP PBX the connecting goes correctly. But when I call from IP PBX to SIP phone the connection does not established. Help to fix it.
NAT router has following config:
interface FastEthernet0/0
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1.89
encapsulation dot1Q 89
ip address 193.109.99.245 255.255.255.248
no ip proxy-arp
ip nat outside
ip nat pool ourpool 193.109.89.246 193.109.89.246 netmask 255.255.255.248
ip nat inside source list 10 pool ourpool overload
access-list 10 permit 192.168.1.0 0.0.0.255
craiglcve Tue, 08/25/2009 - 13:22
What address would the IP PBX be sending the SIP invite to? The issue is that when you call from inside out a nat translation is created that pairs the source address with the destination address. When you call from the IP PBX to the internal phone there is not a translation for the destination. You would need a static translation for the phone so the Router knows who to send the call to.
In a nutshell I think thats whats happening. Hope that helps.
