Bandwidth command in ME 6524
Aug 25th, 2009
I wonder why I can not use "bandwidth" command for configuring CBWFQ in ME 6524. The command is available to use, but when I apply the service policy to the interface, input and output, 6524 gave the following error message:
PE1(config-if)#service-policy input PE-INGRESS-FROM-CE
QoS-ERROR: Addition/Modification made to policymap PE-INGRESS-FROM-CE and class Control-From-Customer is not valid, command is rejected
The software version is as follows:
CG-PE-02#sh version
Cisco IOS Software, s6523_rp Software (s6523_rp-ADVIPSERVICESK9-M), Version 12.2(33)SXH2a, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 25-Apr-08 05:44 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX3, RELEASE SOFTWARE (fc1)
CG-PE-02 uptime is 6 minutes
Uptime for this control processor is 7 minutes
Time since CG-PE-02 switched to active is 5 minutes
System returned to ROM by s/w reset at 06:30:51 UTC Tue Aug 25 2009 (SP by power-on)
System image file is "disk0:s6523-advipservicesk9-mz.122-33.SXH2a.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco ME-C6524GT-8S (R7000) processor (revision 1.3) with 983040K/65536K bytes of memory.
Processor board ID CAT1210C0KM
R7000 CPU at 300Mhz, Implementation 0x27, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
2 Virtual Ethernet interfaces
32 Gigabit Ethernet interfaces
1915K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 256K).
Anybody has a clue?
Even
Giuseppe Larosa Tue, 08/25/2009 - 12:51
  • Hall of Fame,
    Founding Member
Hello Even,
CBWFQ applied inbound is something I never used.
However, there can be some specific requirements of this platform.
Unfortunately, looking for ME 6500 configuration guide points to the configuration guide for 12.2SX for normal C6500 devices.
Looking at the datasheet it lists other queueing mechanisms different for uplink and downlink ports
see
http://www.cisco.com/en/US/prod/collateral/switches/ps6568/ps6845/ps6846/product_data_sheet0900aecd8040657e.html
Priority Queue
Shaped Round Robin (SRR)
Deficit Weighted Round Robin (DWRR)
Weighted Random Early Detection (WRED)
these are switch oriented queueing
Hope to help
Giuseppe
prima.ramadhan Tue, 08/25/2009 - 17:40
Hi Giuseppe,
Thanks for your response.
I actually posted the wrong log. The output when using bandwidth command is as follows:
PE1(config-if)#service-policy output PE-EGRESS-TO-CE
bandwidth command is not supported for this interface
PE1(config-pmap)#do sh policy-map PE-EGRESS-TO-CE
Policy Map PE-EGRESS-TO-CE
Class Control-To-Customer
bandwidth 64 (kbps)
The previous error message is for configuring traffic policing inbound on ME6524, which couldn't be done also.
Anyway, I think what you sad is right. Most QoS toolsets in ME6524 are switch oriented. But it makes me wonder on something else. If I provide MPLS service using this ME6524, how can I limit rate to my customer? I mean if the customer only need 2Mbps, then how do I limit the rate based on their requirement? Because as I said earlier, ME6524 also can not use traffic policing inbound, it can only police outbound. Can you enlighten me?
Edison Ortiz Wed, 08/26/2009 - 09:13
  • Hall of Fame,
    Founding Member
The message posted above is not a policing error but a bandwidth guaranteed configuration error. This is not supported by the regular line cards in the 6500 switch due to the PFC QoS limitation.
You can however police inbound and outbound.
Edison Ortiz Tue, 08/25/2009 - 12:59
  • Hall of Fame,
    Founding Member
ME 6500 relies on the PFC QoS which does not support bandwidth reservation nor shaping.
The command is there as the code is shared by the regular 6500 which supports both features mentioned while using the SIP/SPA combination or FlexWAN.
HTH,
__
Edison.
Giuseppe Larosa Tue, 08/25/2009 - 23:54
  • Hall of Fame,
    Founding Member
Hello Edison,
thanks for your added info
p.s.: compliments for your 10,000 points in Netpro
Best Regards
Giuseppe
Edison Ortiz Wed, 08/26/2009 - 09:11
  • Hall of Fame,
    Founding Member
You are welcome Giuseppe :)
You will get your 10k soon as well..
