cisco 6509 vrf-lite
Aug 25th, 2009
Does Catalyst 6000 supervisor 2 support vrf-lite ? How many routes does cisco 6509 support in an VRF ?
i found that i cannot put the Gigabit and VLAN interface,but can put the loopback into vrf .
S2(config)#int gigabitEthernet 8/8
S2(config-if)#ip vrf forwarding test1
%This interface does not support ip vrf forwarding
(config-if)#
interface Loopback99
ip address 198.19.85.12 255.255.255.255
end
Giuseppe Larosa Thu, 08/27/2009 - 08:17
  • Hall of Fame,
    Founding Member
Hello Liuguiqing,
I remember limitations for supervisor2 for MPLS enabled interfaces that should be on OSM linecards.
As a workaround I would suggest to try to see if an SVI interface like supports VRF
int vlan 100
ip address x.x.x.x y.y.y.y
this should be enough to implement VRF lite.
Hope to help
Giuseppe
