dialer interface not used as dial in (always used as dial out)
Aug 25th, 2009
I have configured the dialer interface on my AS5400. How can i make sure that the dialer interface will not be used for dial in from any one?
I want to make this dialer only for outbound dial out calls only.
Any configuration for that?
slmansfield Thu, 08/27/2009 - 12:21
I wondered whether the "dialer caller" command would prevent any inbound calls through the dialer interface. It is supposed to screen calls by caller ID. However, if your carrier switch is not specifically configured for you to use caller ID this command should reject all inbound calls.
