IPS license
Aug 25th, 2009
Hi all,
how to register IPS to cisco whether it require PAK key to register.Once we get license key how to install in IPS through IDM.
Thanks in advance
Overall Rating: 5 (1 ratings)
Farrukh Haroon Fri, 08/28/2009 - 06:20
You don't need a PAK. Just go to the following page, Scroll Down to the appropriate IPS Hardware/Software version and enter the device' serial number:
https://tools.cisco.com/SWIFT/Licensing/PrivateRegistrationServlet?DemoKeys=Y
Then on the IDM GUI >> Configuration >> Licensing you can download the sensor onto the device.
Have a look at this link:
http://www.cisco.com/en/US/docs/security/ips/6.2/configuration/guide/idm/idm_getting_started.html#wp1064558
Please rate if helpful, Regards
Farrukh
