DND will not stay OFF
pjallipalli
Hi All,
I have an issue where one of my client's cannot have the DND feature switched off. Even if it is manually switched off on each device, it tuns ON after 1 hour.
The user has 5 devices associated with him, and one of them stays OFF a 7975 IP phone and all others return to ON status. He has USE COMMON DEVICE PROFILE set as his individual DND option.
Thanks in advance.
acerda
Hi Sir,
I have a similar issue, did you fix the issue? How? what callmanager version do you use?
Please your suggest
Andres
