ConfigMgmtServer - LMS 3.1
mwynen
Hy.
Everytime the ConfigMgmtServer process is started it will be shut down automatically after 10-20 seconds, but EssentialsDM and DCRServer are running normally.
Why is this happening and how can I fix this?
cheers
Marc
Joe Clarke
Post the ConfigMgmtServer.log and dcmaservice.log.
Hy.
These files are much too big for attaching them. I've copied the end of them into new files, to attach them. Hopefully this is enough.
Thanks for helping me!
cheers
Marc
It appears you have some bad device data in the RME database, and this is crashing ConfigMgmtServer. Without debugging, I cannot see exactly what device is the problem, but even if I could, you would need to open a TAC service request to get the database cleaned up. Once they identify the device ID, they can provide the SQL procedure to tactically remove the bad row from the RME database.
