CLI Command and device support mapping
Aug 25th, 2009
Hi experts,
Is there any utility to know whether the CLI command(s) is(are) supported in particular device series.
For example If I give the "show bootvar"(Support for this command was introduced on the Catalyst 6500 series switches) then i need the list of device images which are supporting this command.
Else If I give the command(say "show bootvar") and Device type like " Catalyst 6500 series switch" then I want to know whether that command is supported in that particular device.
Thanks in Advance...
