Cisco IP Phone (SIP) with the message "calling (out INV)"
Aug 25th, 2009
I have configured a Cisco IP Phone 7940 with the SIP firmware.
Then I have configured a SIP user on the UC500. With this user, I can connect XLite (SIP) to the UC500. Then I use this SIP user on my Cisco IP Phone 7940. On the screen of the phone, I see:
- the number of the Phone
- Your current options
     - Redial, NewCall and CFwdALL
It seems okay, but when I dial a number the following message is on the IP Phone: Calling (out INV)
But there's is no call.
I haven't yet enough know...what I have to do. Maybe you can help me?
Thanks in advance!
wboerendans Tue, 08/25/2009 - 13:40
Okay, let me say what I want:
We have an UC500 on the customer site. There are several remote workers. I will give them a Cisco IP Phone 7940 with the SIP firmware.
They connected the Cisco IP Phone with the SIP firmware at home on the Internet. I change the SIP settings on the phone => proxy server is the WAN IP from the UC500.
My question: this can be a working solution?
Thanks in advance!
wboerendans Wed, 08/26/2009 - 08:39
Another case I try first: Cisco IP Phone with SIP firmware directly (locally) connected on the UC500.
I add the following config:
voice register global
mode cme
source-address 10.1.1.1 port 5060
max-dn 20
max-pool 10
authenticate register
voice register dn  1
number 502
allow watch
voice register pool  1
id mac FFFF.FFFF.FFFF
number 1 dn 1
dtmf-relay sip-notify
username 502 password 502502
codec g711alaw
On the Cisco IP phone I configure this settings...
- Name: 502
- Shortname: 502
- Authentication Name: 502
- Authentication Password: 50502
- Display Name: 502
- Proxy address: 10.1.1.1
- Proxy port: 5060
Is this the right configuration for a SIP phone? Or is there a manual how I can configure this?
Thanks!!
Marcos Hernandez Fri, 08/28/2009 - 11:55
  • Blue, 1500 points or more
What you have here should work fine. Let us know,
marcos
Patrick Saldanha Wed, 02/04/2015 - 13:41
Today I had the same problem: 'Calling (out INV)'
After updating the firmware POS3-07-5-00 for P0S3-8-12-00 the problem was solved.
No need to change anything in my settings.
