Confirming "erase" procedures on 4507
Aug 25th, 2009
Hi, if I need to clear all configuration on my 4507 (but leave the existing IOS on flash OK, I am planning to get to console on each supervisor and do:
Switch#write erase
then reload it.
Is that all or anything special I need to do when dealing with the supervisor engine?
glen.grant Tue, 08/25/2009 - 07:17
That will wipe out any config minus anything that is in the vlan.dat file .
news2010a Tue, 08/25/2009 - 07:27
I did 'write erase' and I see that vlan information was wiped out. I just see a vlan 20 and obviously vlan 1.
glen.grant Tue, 08/25/2009 - 07:46
Right if it had wiped out everything you would not see a vlan 20 . The main config is wiped out but the vlan info in the vlan.dat is there . I would just manually get rid of vlan 20 .
conf t
no vlan 20
news2010a Tue, 08/25/2009 - 07:49
Actually that may not be correct. It sounds vlan got wiped out by configuration on the first supervisor...
Thanks.
