Unity Connection upgrade from 2x to 7x
Aug 25th, 2009
Hi we are upgrading from 2.x to 7.x so that we can use the feature ' smtp message relay' - is there a way of bulk updating the existing users so this new feature can be enabled for all users?...cheers, jag
Rob Huffman Tue, 08/25/2009 - 07:41
Hi Jag,
You should be able to update these via the Bulk Edit utility > Message Actions > Accept and Relay (action)
Cheers!
Rob
jeff.singh_2 Tue, 08/25/2009 - 08:54
Rob,
can you select all the users at once and add thier smtp addresses from a csv ?
jeff.singh_2 Mon, 09/14/2009 - 06:20
for a user account, under edit, smtp address theres a field there. Under mesage action, to forward messages to an smtp address i have to enter an smtp address, how can I do this using BAT?
