Unity Cobras Migration
casey1hunter
I have a Unity 4.X enviroment with Voicemail only. Can COBRAS migrate that existing data to Unity 7.X in a UM enviroment?
Jaime Valencia
Yes you can, just as DIRT before you can move UM/VMO backups
java
if this helps, please rate
java
You can pull down the appropriate version ov COBRAS from answermonkey.net There are 2 variations. Import and Export. Install the Cobra export tool and run it. You will be prompted for what type of data you would like to export such as greetings, callhandlers, etc. Once you install unity version 7 you will install the Import version of Cobra and import the data from the original export.
This tool works great. You may know already but you can import a dirt backup to a different version of Unity.
denglebrick
Can you explain how its done?
