utu error on lms 3.1
Answered Question
Aug 25th, 2009
I got this error when I am trying to use utu " campus manager is not in http mode" what I need to do to enable http mode"
A.
Correct Answer by Joe Clarke about 7 years 8 months ago
When you access your LMS server, and you're looking at the CiscoWorks portal, what is the URL? Is it http or https? When you have the protocol, right-click in the UTU text field, and select Configure... Then, if you're using https, check the "Enable SSL" box. If not, leave that box unchecked.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Tue, 08/25/2009 - 08:16
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
