Remote VPN Client and Telnet to ASA
asfar.zaidi
Hi Guys
I ahve a ASA firewall Connected to Cisco 2821 Router.
On the Router I have ADSL and Lease Line connected.
All my traffic destined for port web ftp etc is going from ADSL and smtp pop3 telnet etc is going from lease Line.
My issues as follow:
I am unable to telnet to ASA outside Interface although its configuered.
Unable to connect my Remote VPN Client , there are no packets in debug crypto isakmp , I know I ahve a nat device i.e. my router before my asa , I have to no nat port 4500 and esp over there but how , its confusing.
I am ataching configuration.
It's look like a config issue. Might need debug output of "debug crypto isa 127".
You might need remove command "authorization-server-group LOCAL".
NAT-traversal is enabled by default on ASA version 8.x. Therefore, you don't need worry NAT device in the middle.
14 Replies 14
Yudong Wu
Level 7
Level 7
Is aa.aa.aa.2 a public IP? If yes, will the packet to aa.aa.aa.2 come in from ADSL?
Make sure the packet to aa.aa.aa.2 will reach ASA. You can enable logging buffer or setup capture on outside interface. Then try telnet to ASA and check log or capture to see if telnet packet reach ASA.
Yes its a Public IP. and Packet should come from LL not from ADSL (That what I think).
I captured , but telnet is not reaching till ASA.
If you do the capture on ASA like following,
access-list cap permit tcp any host aa.aa.aa.2 eq telnet
access-list cap permit tcp host aa.aa.aa.2 eq telnet any
capture cap access-list cap interface outside
- telent to ASA outside interface from somewhere else.
- then on ASA, show capture cap
Do you see the packet in and out?
This is the Packet Capture
5 packets captured
1: 22:51:11.754981 217.164.167.147.61152 > aa.aa.aa.2.23: S 2487757828:24
87757828(0) win 65535
K>
2: 22:51:14.838671 217.164.167.147.61152 > aa.aa.aa.2.23: S 2487757828:24
K>
3: 22:51:20.878464 217.164.167.147.61152 > aa.aa.aa.2.23: S 2487757828:24
K>
4: 22:51:32.997156 217.164.167.147.61152 > aa.aa.aa.2.23: S 2487757828:24
K>
5: 22:51:57.058270 217.164.167.147.61152 > aa.aa.aa.2.23: S 2487757828:24
K>
5 packets shown
Did you capture the packet by using the ACL in my previous post? If yes, you should be able to capture the packet in both directions. From output, it looks like ASA did not response to telnet request. Can you enable logging buffered and then try telnet again and check "show logging" to see if there is log info for this.
Yes I capture the packet as you told me and this is the output for show logging
%ASA-4-402117: IPSEC: Received a non-IPSec packet (protocol= TCP) from 217.164.167.147 to aa.aa.aa.2.
%ASA-7-710005: TCP request discarded from 217.164.167.147/61771 to outside:aa.aa.aa.2/23
%ASA-7-710005: TCP request discarded from 217.164.167.147/61823 to outside:aa.aa.aa.2/23
Ok, you can not telnet to an outside interface directly. It must go through VPN tunnel. but you should be able to SSH to outside interface directly.
Ok, but why it should go through VPN Tunnel.
Secondly , I am unable to get VPN up even
1. That's by design. Telnet to outside is not safe since the packet is in plain text.
2. Looks like you missed "crypto isakmp enable outside".
Thanks ... you are right .... I enable it and getting this error
(config)# Aug 25 23:47:42 [IKEv1]: Group = AdminGrp, IP = 217.164.167.147, Removing peer from peer table failed, no match!
Aug 25 23:47:42 [IKEv1]: Group = AdminGrp, IP = 217.164.167.147, Error: Unable to remove PeerTblEntry
Aug 25 23:47:47 [IKEv1]: Group = AdminGrp, IP = 217.164.167.147, Removing peer from peer table failed, no match!
Aug 25 23:47:47 [IKEv1]: Group = AdminGrp, IP = 217.164.167.147, Error: Unable to remove PeerTblEntry
Aug 25 23:47:52 [IKEv1]: Group = AdminGrp, IP = 217.164.167.147, Removing peer from peer table failed, no match!
Aug 25 23:47:52 [IKEv1]: Group = AdminGrp, IP = 217.164.167.147, Error: Unable to remove PeerTblEntry
Aug 25 23:47:57 [IKEv1]: Group = AdminGrp, IP = 217.164.167.147, Removing peer from peer table failed, no match!
Aug 25 23:47:57 [IKEv1]: Group = AdminGrp, IP = 217.164.167.147, Error: Unable to remove PeerTblEntry
By the way tell me one thing I have a nat device above the ASA , why i dont need to bypass the port 4500 on it
I change the group 5 to 2 and it start working.
Great! I am glad you found the mistaken in config. Good job.
