HDD upgrade for CUCM 5.1
Aug 25th, 2009
  • Cisco Employee,
Hi all
I'm facing an issue with CUCM 5.1 on MCS 7835 H2 server(with two 72 GB SCSI). The hard disk utilization is 91% for both the active and inactive partitions. Please advise me on how to free some diskspace or how to upgrade the HDD if required.
Overall Rating: 4 (1 ratings)
Jaime Valencia Tue, 08/25/2009 - 09:35
  • Cisco Employee,
  • Hall of Fame,
    2011
That HDD usage is fine, up to 94% there is no problem.
If you still want to free space delete old trace files and send CDR to another server.
java
if this helps, please rate
vdominic Tue, 08/25/2009 - 09:48
  • Cisco Employee,
Thx Jaime, for the quick reply.
Is it possible to upgrade HDD as in 4.x versions, with a re-install after server platform upgrade. I guess that wont work as the appliance is optimized for the specific hardware.
Jaime Valencia Tue, 08/25/2009 - 13:45
  • Cisco Employee,
  • Hall of Fame,
    2011
You're correct.
During the install the HDD size is used to determine the size of all the linux partitions so it's not the same using 72 GB than using 146 HDD.
I'm pre-assuming your server does support HDD upgrade so a backup, HDD upgrade, install, restore does work.
Think of it as upgrading the whole MCS platform, the new server might have bigger disks/faster CPU/ more RAM but you can still restore a CUCM backup.
java
