Shortcut key to break out of telnet sessions?
Answered Question
Aug 25th, 2009
All,
I can telnet from Router A -> B -> C -> D.
Now, from router D, I can ctrl-shift-6-x and get back to router A. Router A will show one connection to router B. How, if even possible, would I be able to break from Router D to Router C without quitting the telnet session? Is there a keystroke that will let you do that?
Also, does anyone (Edison?) have a list of Cisco supported, undocumented keystrokes? I've looked and can't find much on it.
John
Correct Answer by Edison Ortiz about 7 years 6 months ago
To get back to the device you telneted from per your example from D to C;
Do this:
control-shift-6
Then
control-shift-6-x
Overall Rating: 5 (2 ratings)
Correct Answer
Edison Ortiz Tue, 08/25/2009 - 09:27
Do this:
control-shift-6
Then
control-shift-6-x
