Unity or Unity Connection via SIP to CUCM
Aug 25th, 2009
Is there a simple way to get an IP Phone display to show that they are calling Voicemail and the number when Unity or Unity Connection is using a SIP integration with CUCM like we can if it's integrated via SCCP?
A SIP integration only seems to display just the digits.
You can configure the display name for Unity Connection under Telephony Integrations, Port Group, Contact Line Name.
For Unity 7.0 you can configure this setting for a SIP integration in the UTIM. Go to the integration in question and browse to the SIP Info tab. Enter your diplay name in the Contact Line Name. However....it will not work!!! I have a TAC case that is resulting in a feature request to get this working. Unity sends the information in the SIP packet, but CM is not doing what it needs to do with it, or expecting it in another element or something of that nature. Don't kill yourself on it, though.
