Disabling a switch port for specific time interval
Aug 25th, 2009
Hi can any one guide on how we can disable a specific switch port on Catalyst 2960 switches for a specific period of time. NTP is running on the switch.
Joe Clarke Tue, 08/25/2009 - 21:40
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I just saw this posted on another thread I'm working on:
time-range test
periodic weekend 0:01 to 23:59
access-list 105 deny ip any any time-range test
access-list 105 permit ip any any
int fa0/8
ip access-group 105 in
This blocks all IP traffic on a port for a given time range.
Another solution is to use the Embedded Event Manager to shutdown the port at a given time. The EEM solution would require IOS 12.2(40)SE or higher. You could do something like:
event manager applet shutdown-port
event timer cron cron-entry "0 17 * * *"
action 1.0 cli command "enable"
action 2.0 cli command "config t"
action 3.0 cli command "interface Fa0/8"
action 4.0 cli command "shut"
action 5.0 cli command "end"
action 6.0 syslog msg "Port FastEthernet0/8 taken down"
event manager applet up-port
event timer cron cron-entry "0 8 * * *"
action 4.0 cli command "no shut"
action 6.0 syslog msg "Port FastEthernet0/8 brought back up"
This will take down port Fa0/8 at 17:00, and bring it backup at 8:00.
