Conference Calls getting dropped!!!
Aug 25th, 2009
Hi all
I have a CCM 4.2 which has a conference bridge(S/W) configured and registered with it.It has been working fine before a couple of months and now when we tried making conference calls, the calls are getting dropped.We are trying for Ad-Hoc Con calls.
FYI:No upgrades have been performed on the server in the meantime.
Any advice is highly appreciated!!!
Jaime Valencia Wed, 08/26/2009 - 09:01
Exactly when is this happening, you're on conference and it drops??
Or you're establishing conference and it fails??
If 2nd check for codec issues.
for 1st have you tried bouncing the IPVMS??
java
if this helps, please rate
josephjameslibin Wed, 08/26/2009 - 20:42
2nd one is the problem.
Fails when we try to establish con calls.
Receives the error "No Device Information".
And I am pretty sure that the con call is among phones in the same region.So codec remains the same for all of them, correct!!!
