Calling Searchspaces and Partitions
Answered Question
Aug 26th, 2009
The H.323 gateway incomming CSS only calls the first partion in the CSS list.Any partions after that it gives a busy.
Scenario I have phones in different partitions and I have applied the gateway with a CSS that contains all these partitions however that gateway can only contact the first partition.
At the moment I have to keep all phones in the same partition. I dont want this I want other phones to be in different partitions to take advantage of DID.
Thanks Guys
Correct Answer by Dennis Mink about 7 years 8 months ago
have you tried deleting the CSS and then re-add?
Overall Rating: 5 (1 ratings)
Correct Answer
Dennis Mink Wed, 08/26/2009 - 01:21
  • Gold, 750 points or more
jimihendrix1 Wed, 08/26/2009 - 02:24
I created a brand new CSS and added the appropiate partitions it did not work as I did not want to use dependancy records if I deleted original CSS.
Then finally I deleted the original CSS added partitions and works perfectly now.
Cheers minkdennis
