3 FR Link with Single DLCI Number
Aug 26th, 2009
Hi All,
Our service provider gives us 3 separate E1's. They told us to configure our router's sub serial interfaces and give us only 1 dlci number. Is this the right way of doing this? Only one dlci for the 3 separated E1 links?
Im aware of the multiple dlci's on one interface but this one, im a little bit confused.
I will much appreciate any of your help guys....
Thanks in advance cisco guru's! More power to cisco world.
Peter Paluch Wed, 08/26/2009 - 02:24
  • Cisco Employee,
Hi Chester,
How are these three E1 lines terminated on your router? Is each of them terminated on a separate physical interface? If yes then a single DLCI will work just fine because each interface maintains its own table of DLCIs and mappings so there is no ambiguosity.
Best regards,
Peter
cmadiam82 Wed, 08/26/2009 - 02:41
Many thanks paluchpeter for your quick reply.
Yes! This three E1 lines are terminated on separate physical interfaces.
Thanks also p.bevilacqua.
Guys, your doing greate!!!
paolo bevilacqua Wed, 08/26/2009 - 02:24
  • Hall of Fame,
    Founding Member
Yes, DLCI have local meaning to the interface only so it can be reused.
