08-26-2009 03:19 AM
I recived the CWLMS3.2-5KSRK9 package, but when run setup.sh,I've the below message:
bash-2.05# ./setup.sh
./setup.sh: /install/configureMe: not found
Solved! Go to Solution.
08-29-2009 01:15 PM
Certainly what you're doing is not supported. It really sounds like HP/UX is not preserving the case of the files on the DVD. That is, the setup script expects to find a configureMe file in the root of the DVD, and this isn't there. I think "cdcase" is making all of the file names lowercase. If you absolutely cannot mount the DVD on a Solaris machine, try mounting the DVD with:
/usr/sbin/mount -F cdfs -e -o ro,rr /dev/dsk/c0t1d0 /cdrom
That should preserve the case based on the Rockridge Extensions. Then, to properly copy the contents to disk, use tar:
# cd /cdrom
# tar -cpf /path/to/lms.tar .
Then, copy the lms.tar file to the Solaris machine, and untar it with:
# tar -xpf lms.tar
08-26-2009 07:36 AM
Did you copy the DVD contents to disk? If so, how did you do this?
08-28-2009 11:32 PM
Yes,I did by mount cdrom on HPux and run rcp command on ciscoworks server "rcp -rp"
the command to mount cdrom on hpux is :
"mount -o ro,cdcase /dev/dsk/c0t1d0 /cdrom"
08-29-2009 01:15 PM
# cd /cdrom
# tar -xpf lms.tar
