NAC Guest server with tokens
Dirks
Has anybody implemented NAC guest server in conjunction with SMS tokens.
Is there some docs. on how to?
vmoopeung
Level 5
Level 5
The following APIs allow administrators to create, delete, and view local user accounts on the CAM:
•getlocaluserlist
•addlocaluser
•deletelocaluser
Local users are those internally validated by the CAM as opposed to an external authentication server. These APIs are intended to support guest access for dynamic token user access generation, providing the ability to:
•Use a webpage to access Cisco NAC Appliance API to insert a visitor username/password combination, such as jdoe@visitor.com/jdoe112805, and then assign a role, such as guest1day.
•Delete all guest users associated with the guest access role for that day.
•List all usernames associated with the guest access role.
These APIs support most implementations of guest user access dynamic token/password generation and allow the removal of those users for a guest role.
You must create the front-end generation password/token. For accounting purposes, Cisco NAC Appliance provides RADIUS accounting functionality only.
http://www.cisco.com/en/US/docs/security/nac/appliance/configuration_guide/413/cam/m_apiapx.html#wp1012025
