Are the Cisco 521S phones problematic?
Aug 26th, 2009
I am implementing a solution with the UC520 24 users with Cisco 7931 Receptionist phones and Cisco 521SG phones.  I am facing several issues, and my customer is not impressed so far.
Issue 1:
No matter what I do, I simply cannot get the switchport on the phone to activate. The ethernet port on my laptop does not see any activity when I connect the cable to it.  The phone is labelled 521S, on the box it says 521SG and the customer is expecting an extra switchport at every desk.  On the UC 520, it picks up some as 521G and some as 524G!!!!!!   wtf.
Issue 2:
After connecting all the phones to the 2960 PoE switch that I have, I see that the PoE negotiates correctly, and picks up the correct phone, in this case IP Phone CP-521S.   After a while, it drops a whole bunch of them to Ieee PD.  The phones still work, but I can no longer see these devices as CDP neighbors.
Also, on one occassion, all phones were switch ofd, except the 7931 Receptionist phone which connects to the same Ethernet switch.
I was told by the dealer to update the IOS and the phone load for that phone to the latest version, which I did, but still no luck.
Customer was also given a Polywell/Trixbox solution as well, but decided to go with Cisco to avoid the problems that I am presenting them with.
stuv
Steven Smith Wed, 08/26/2009 - 07:54
Can you do a show ephone phone-load?  That will say what the phone is running.
stuv Wed, 08/26/2009 - 07:59
hi
okay, here we go.
TPOC-UC520# show ephone phone-load
DeviceName        CurrentPhoneload       PreviousPhoneload      LastReset
SEP00211BFC8F42   8.1.7                  8.1.7                  Hard+Unknown
SEP00211BFC8DCE   8.1.10                 8.1.10                 Hard+Unknown
SEP001A4B682D14    7.0.1.0                7.0.1.0               Reset-Restart
SEP00211BFC87BB   8.1.7                  8.1.7                  Hard+Unknown
SEP00211BFC8DC6   8.1.10                 8.1.10                 Hard+Unknown
SEP00211BFC8DC8   8.1.10                 8.1.10                 Hard+Unknown
SEP00211BFC9F02   8.1.10                 8.1.10                 Hard+Unknown
SEP00211BFC8DCC   8.1.10                 8.1.10                 Hard+Unknown
SEP00211BFC87BE   8.1.10                 8.1.10                 Hard+Unknown
SEP00211BFC8375   8.1.10                 8.1.10                 Hard+Unknown
SEP00211BFC8F44   8.1.10                 8.1.10                 Hard+Unknown
SEP00211BFC8377   8.1.10                 8.1.10                 Hard+Unknown
SEP00211BFC8F43   8.1.10                 8.1.10                 Hard+Unknown
SEP00211BFC8D09   8.1.10                 8.1.10                 Hard+Unknown
SEP002545944A05    SCCP31.8-3-3SR2S       SCCP31.8-3-3SR2S      Initialized
SEP00211BFC8D08   8.1.10                 8.1.10                 Hard+Unknown
SEP00211BFC8D0E   8.1.10                 8.1.10                 Hard+Unknown
SEP00211BFC8D0D   8.1.10                 8.1.10                 Hard+CMERequest
SEP00211BFC8D0A   8.1.10                 8.1.10                 Hard+Unknown
SEP00211BFC8D0B   8.1.10                 8.1.10                 Hard+CMERequest
SEP00211BFC8D07   8.1.10                 8.1.10                 Hard+CMERequest
SEP00211BFC8D0C   8.1.10                 8.1.10                 Hard+CMERequest
SEP0023AE228AFD    7.0.1.0                7.0.1.0               UCM-closed-TCP
TPOC-UC520#
I also have this in my flash
137     892426 Aug 25 2009 15:48:38 +03:00 phones/521_524/cp524g-8-1-16b.bin
I have this in telephony-service
load 521G-524G cp524g-8-1-16b
Steven Smith Wed, 08/26/2009 - 08:09
Can you post your config?  Remember to remove passwords before you post.
David Trad Wed, 08/26/2009 - 18:02
Hi Stuv,
If you are willing to try this upgrade path, have a look at this release:
https://upload.cisco.com/cgi-bin/swc/fileexg/main.cgi/UC520-7.1.1a-ea.zip?menu=download&file=124133.bin&encrypted_flag=0&file_name=FileExg/24142/124133.bin/UC520-7.1.1a-ea.zip&CONTYPES=UC500&sub_forum=UC500%20Software%20Pack%20Early%20Adopter
It is an Early Adopter release which means it might contain some bugs in it.
If you used CCA to upgrade the phone loads then it should work as required and the TFTP and Telephony-service sections should have been upgraded.
Lets see your config as that might also give away some information relating to your problem as well.
Just make sure you do remove any sensative information of that system you would not want release to public viewing.
Cheers,
David.
stuv Thu, 08/27/2009 - 08:05
Hi there
I have upgraded the 2960 as well to the latest IOS available
#sh ver
Cisco IOS Software, C2960 Software (C2960-LANBASE-M), Version 12.2(50)SE3, RELEASE SOFTWARE (fc1)
#sh power inline
Available:370.0(w)  Used:126.7(w)  Remaining:243.3(w)
Interface Admin  Oper       Power   Device              Class Max
                            (Watts)
Fa0/1     auto   off        0.0     n/a                 n/a   15.4
Fa0/2     auto   off        0.0     n/a                 n/a   15.4
Fa0/3     auto   on         6.3     Ieee PD             2     15.4
Fa0/4     auto   on         6.3     Ieee PD             2     15.4
Fa0/5     auto   off        0.0     n/a                 n/a   15.4
Fa0/6     auto   on         6.3     Ieee PD             2     15.4
I have uploaded the phone loads, (I tried several times to do it via CCA but could not find the correct way to do it).  I uploaded it with TFTP.
archive tar /xtract tftp://192.168.123.123/CME-Phone-Loads-7.0.3.tar flash:
I rebooted the router, the switch and the phones and it still shows the old phone-loads.
David Trad Thu, 08/27/2009 - 15:12
Hi Stuv,
OK i have had a look at your config, nothing jumped out at me so i couldnt see anything wrong, your TFTP-SERVER looked ok so did your telephony-service as well.
I would try to factory reset the phones now, you should be able to do this via the menu of the phone, once you do that unplug it and then let it load back up again.
Can you also run the following on the command line please:
ROUTER# debug tftp events
ROUTER# term mon
The above command should be able to show us if the phone is seeking the right phone loads, if it is not it will show up some errors, if you can the messages that come up on the screen would be much appreciated if you can send them to us or post it on here.
Cheers,
David.
stuv Fri, 08/28/2009 - 01:49
Hi there
I here are the debug events
Aug 28 08:27:36.363: TFTP: Looking for SEP00211BFC8D0B.cnf.xml
Aug 28 08:27:36.363: TFTP: Opened system:/its/XMLDefault521G.cnf.xml, fd 10, size 1101 for process 146
Aug 28 08:27:36.367: TFTP: Finished system:/its/XMLDefault521G.cnf.xml, time 00:00:00 for process 146
Aug 28 08:27:36.375: TFTP: Looking for cp524g-8-1-16b.BIN
Aug 28 08:27:36.387: TFTP: Looking for RingList.xml
Aug 28 08:27:36.387: TFTP: Looking for DistinctiveRingList.xml
Aug 28 08:27:36.459: TFTP: Looking for English_United_States/524-dictionary.xml
Aug 28 08:27:36.619: %IPPHONE-6-REG_ALARM: Name=SEP00211BFC8D0B  Load=8.1.10 Last=Hard+Unknown
Aug 28 08:27:36.819: %IPPHONE-6-UNREGISTER_ABNORMAL: ephone-21:SEP00211BFC8D0B IP:10.1.1.15 Socket:7 DeviceType:Phone has unregistered abnormally.
Aug 28 08:27:36.819: %IPPHONE-6-REGISTER: ephone-21:SEP00211BFC8D0B IP:10.1.1.15 Socket:12 DeviceType:Phone has registered.
Aug 28 08:27:51.499: TFTP: Looking for /CP-521S-cfg.xml
ephone-21[20] Mac:0021.1BFC.8D0B TCP socket:[12] activeLine:0 REGISTERED in SCCP ver 8/8 SPCP ver 1/1
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:12
IP:10.1.1.15 44971 CP-521G  keepalive 36 max_line 1
button 1: dn 35 number 353 CH1   IDLE         CH2   IDLE
Preferred Codec: g711ulaw
Username: uc18
SEP002545944A05    SCCP31.8-3-3SR2S                             Initialized
SEP00211BFC8D0B   8.1.10                 8.1.10                 Hard+Unknown
Still the old one phone load.  Here is a directory listing of flash.
# sh flash
-#- --length-- -----date/time------ path
1          660 Aug 27 2009 17:55:34 +03:00 vlan.dat
2     28064464 Aug 27 2009 16:43:20 +03:00 uc500-advipservicesk9-mz.124-20.T2
3            0 Aug 27 2009 17:09:32 +03:00 phones
4            0 Aug 27 2009 17:09:32 +03:00 phones/7975
5          642 Aug 27 2009 17:10:12 +03:00 phones/7975/term75.default.loads
6      2918613 Aug 27 2009 17:09:46 +03:00 phones/7975/apps75.8-4-1-23.sbn
7       485244 Aug 27 2009 17:09:50 +03:00 phones/7975/cnu75.8-4-1-23.sbn
8      2661855 Aug 27 2009 17:10:04 +03:00 phones/7975/cvm75sccp.8-4-1-23.sbn
9       335003 Aug 27 2009 17:10:06 +03:00 phones/7975/dsp75.8-4-1-23.sbn
10      757132 Aug 27 2009 17:10:10 +03:00 phones/7975/jar75sccp.8-4-1-23.sbn
11         638 Aug 27 2009 17:10:12 +03:00 phones/7975/SCCP75.8-4-2S.loads
12           0 Aug 27 2009 17:10:12 +03:00 phones/7970_7971
13         642 Aug 27 2009 17:10:52 +03:00 phones/7970_7971/term71.default.loads
14         642 Aug 27 2009 17:10:52 +03:00 phones/7970_7971/term70.default.loads
15     2915997 Aug 27 2009 17:10:28 +03:00 phones/7970_7971/apps70.8-4-1-23.sbn
16      460275 Aug 27 2009 17:10:30 +03:00 phones/7970_7971/cnu70.8-4-1-23.sbn
17     2665016 Aug 27 2009 17:10:44 +03:00 phones/7970_7971/cvm70sccp.8-4-1-23.sbn
18      539441 Aug 27 2009 17:10:48 +03:00 phones/7970_7971/dsp70.8-4-1-23.sbn
19      700829 Aug 27 2009 17:10:52 +03:00 phones/7970_7971/jar70sccp.8-4-1-23.sbn
20         638 Aug 27 2009 17:10:52 +03:00 phones/7970_7971/SCCP70.8-4-2S.loads
21           0 Aug 27 2009 17:10:52 +03:00 phones/7945_7965
22         642 Aug 27 2009 17:11:32 +03:00 phones/7945_7965/term45.default.loads
23         642 Aug 27 2009 17:11:34 +03:00 phones/7945_7965/term65.default.loads
24     2918613 Aug 27 2009 17:11:08 +03:00 phones/7945_7965/apps45.8-4-1-23.sbn
25      485266 Aug 27 2009 17:11:12 +03:00 phones/7945_7965/cnu45.8-4-1-23.sbn
26     2662633 Aug 27 2009 17:11:26 +03:00 phones/7945_7965/cvm45sccp.8-4-1-23.sbn
27      335003 Aug 27 2009 17:11:28 +03:00 phones/7945_7965/dsp45.8-4-1-23.sbn
28      754716 Aug 27 2009 17:11:32 +03:00 phones/7945_7965/jar45sccp.8-4-1-23.sbn
29         638 Aug 27 2009 17:11:32 +03:00 phones/7945_7965/SCCP45.8-4-2S.loads
30           0 Aug 27 2009 17:11:34 +03:00 phones/7942_7962
31         662 Aug 27 2009 17:12:14 +03:00 phones/7942_7962/term62.default.loads
32         662 Aug 27 2009 17:12:14 +03:00 phones/7942_7962/term42.default.loads
33     2918613 Aug 27 2009 17:11:48 +03:00 phones/7942_7962/apps42.8-4-1-23.sbn
34      485066 Aug 27 2009 17:11:52 +03:00 phones/7942_7962/cnu42.8-4-1-23.sbn
35     2659498 Aug 27 2009 17:12:06 +03:00 phones/7942_7962/cvm42sccp.8-4-1-23.sbn
36      335003 Aug 27 2009 17:12:08 +03:00 phones/7942_7962/dsp42.8-4-1-23.sbn
37      628112 Aug 27 2009 17:12:12 +03:00 phones/7942_7962/jar42sccp.8-4-1-23.sbn
38         658 Aug 27 2009 17:12:12 +03:00 phones/7942_7962/SCCP42.8-4-2S.loads
39           0 Aug 27 2009 17:12:14 +03:00 phones/7941_7961
40         642 Aug 27 2009 17:12:54 +03:00 phones/7941_7961/term41.default.loads
41         642 Aug 27 2009 17:12:56 +03:00 phones/7941_7961/term61.default.loads
42     2915997 Aug 27 2009 17:12:30 +03:00 phones/7941_7961/apps41.8-4-1-23.sbn
43      459836 Aug 27 2009 17:12:34 +03:00 phones/7941_7961/cnu41.8-4-1-23.sbn
44     2660448 Aug 27 2009 17:12:48 +03:00 phones/7941_7961/cvm41sccp.8-4-1-23.sbn
45      539441 Aug 27 2009 17:12:50 +03:00 phones/7941_7961/dsp41.8-4-1-23.sbn
46      500440 Aug 27 2009 17:12:54 +03:00 phones/7941_7961/jar41sccp.8-4-1-23.sbn
47         638 Aug 27 2009 17:12:54 +03:00 phones/7941_7961/SCCP41.8-4-2S.loads
48           0 Aug 27 2009 17:12:56 +03:00 phones/7940_7960
49      130548 Aug 27 2009 17:12:56 +03:00 phones/7940_7960/P00308001000.bin
50         458 Aug 27 2009 17:12:58 +03:00 phones/7940_7960/P00308001000.loads
51      707328 Aug 27 2009 17:13:02 +03:00 phones/7940_7960/P00308001000.sb2
52      130952 Aug 27 2009 17:13:02 +03:00 phones/7940_7960/P00308001000.sbn
53           0 Aug 27 2009 17:13:02 +03:00 phones/7937
54     7922596 Aug 27 2009 17:13:44 +03:00 phones/7937/apps37sccp.1-3-2-0.bin
55           0 Aug 27 2009 17:13:44 +03:00 phones/7936
56     1849756 Aug 27 2009 17:13:54 +03:00 phones/7936/cmterm_7936.3-3-16-0.bin
57           0 Aug 27 2009 17:13:54 +03:00 phones/7931
58         643 Aug 27 2009 17:14:32 +03:00 phones/7931/term31.default.loads
59     2925555 Aug 27 2009 17:14:08 +03:00 phones/7931/apps31.8-4-1-23.sbn
60      464028 Aug 27 2009 17:14:12 +03:00 phones/7931/cnu31.8-4-1-23.sbn
61     2661176 Aug 27 2009 17:14:26 +03:00 phones/7931/cvm31sccp.8-4-1-23.sbn
62      335003 Aug 27 2009 17:14:28 +03:00 phones/7931/dsp31.8-4-1-23.sbn
63      485636 Aug 27 2009 17:14:30 +03:00 phones/7931/jar31sccp.8-4-1-23.sbn
64         639 Aug 27 2009 17:14:32 +03:00 phones/7931/SCCP31.8-4-2S.loads
65           0 Aug 27 2009 17:14:32 +03:00 phones/7925
66     1883285 Aug 27 2009 17:14:56 +03:00 phones/7925/GUIH-1.3.1.SBN
67      936361 Aug 27 2009 17:15:12 +03:00 phones/7925/TNUXH-1.3.1.SBN
68         819 Aug 27 2009 17:14:46 +03:00 phones/7925/CP7925G-1.3.1.LOADS
69     2628733 Aug 27 2009 17:14:46 +03:00 phones/7925/APPSH-1.3.1.SBN
70     1963130 Aug 27 2009 17:15:24 +03:00 phones/7925/WLANH-1.3.1.SBN
71     2118665 Aug 27 2009 17:15:08 +03:00 phones/7925/SYSH-1.3.1.SBN
72           0 Aug 27 2009 17:15:24 +03:00 phones/7921
73     1833102 Aug 27 2009 17:15:48 +03:00 phones/7921/GUI-1.2.1.SBN
74      895905 Aug 27 2009 17:16:02 +03:00 phones/7921/TNUX-1.2.1.SBN
75     2083047 Aug 27 2009 17:15:58 +03:00 phones/7921/SYS-1.2.1.SBN
76     2593969 Aug 27 2009 17:15:36 +03:00 phones/7921/APPS-1.2.1.SBN
77         894 Aug 27 2009 17:15:38 +03:00 phones/7921/CP7921G-1.2.1.LOADS
78     1350650 Aug 27 2009 17:16:22 +03:00 phones/7921/WLAN-1.2.1.SBN
79     2196478 Aug 27 2009 17:16:14 +03:00 phones/7921/TNUXR-1.2.1.SBN
80           0 Aug 27 2009 17:16:22 +03:00 phones/7916
81      165355 Aug 27 2009 17:16:24 +03:00 phones/7916/B016-1-0-3.SBN
82           0 Aug 27 2009 17:16:24 +03:00 phones/7915
83      146463 Aug 27 2009 17:16:26 +03:00 phones/7915/B015-1-0-3.SBN
84           0 Aug 27 2009 17:16:26 +03:00 phones/7914
85       49986 Aug 27 2009 17:16:26 +03:00 phones/7914/S00105000300.sbn
86           0 Aug 27 2009 17:16:26 +03:00 phones/7906_7911
87         662 Aug 27 2009 17:17:06 +03:00 phones/7906_7911/term06.default.loads
88         662 Aug 27 2009 17:17:06 +03:00 phones/7906_7911/term11.default.loads
89     2925555 Aug 27 2009 17:16:42 +03:00 phones/7906_7911/apps11.8-4-1-23.sbn
90      463556 Aug 27 2009 17:16:44 +03:00 phones/7906_7911/cnu11.8-4-1-23.sbn
91     2666103 Aug 27 2009 17:17:00 +03:00 phones/7906_7911/cvm11sccp.8-4-1-23.sbn
92      335003 Aug 27 2009 17:17:02 +03:00 phones/7906_7911/dsp11.8-4-1-23.sbn
93      485341 Aug 27 2009 17:17:04 +03:00 phones/7906_7911/jar11sccp.8-4-1-23.sbn
94         658 Aug 27 2009 17:17:06 +03:00 phones/7906_7911/SCCP11.8-4-2S.loads
95           0 Aug 27 2009 17:17:06 +03:00 phones/525
96     9871691 Aug 27 2009 17:17:58 +03:00 phones/525/spa525g-7-1-9.bin
97           0 Aug 27 2009 17:17:58 +03:00 phones/521_524
98      892426 Aug 27 2009 17:18:02 +03:00 phones/521_524/cp524g-8-1-16b.bin
99           0 Aug 27 2009 17:54:28 +03:00 Desktops
100     131470 Aug 27 2009 17:54:30 +03:00 Desktops/CampusNight.png
101      80565 Aug 27 2009 17:54:30 +03:00 Desktops/CiscoFountain.png
102       8156 Aug 27 2009 17:54:32 +03:00 Desktops/CiscoLogo.png
103     138278 Aug 27 2009 17:54:32 +03:00 Desktops/Fountain.png
104     109076 Aug 27 2009 17:54:34 +03:00 Desktops/MorroRock.png
105     108087 Aug 27 2009 17:54:34 +03:00 Desktops/NantucketFlowers.png
106      10820 Aug 27 2009 17:54:36 +03:00 Desktops/TN-CampusNight.png
107       9657 Aug 27 2009 17:54:36 +03:00 Desktops/TN-CiscoFountain.png
108       2089 Aug 27 2009 17:54:36 +03:00 Desktops/TN-CiscoLogo.png
109       7953 Aug 27 2009 17:54:36 +03:00 Desktops/TN-Fountain.png
110       7274 Aug 27 2009 17:54:36 +03:00 Desktops/TN-MorroRock.png
111       9933 Aug 27 2009 17:54:38 +03:00 Desktops/TN-NantucketFlowers.png
112          0 Aug 27 2009 17:54:38 +03:00 Desktops/320x216x16
113        651 Aug 27 2009 17:54:38 +03:00 Desktops/320x216x16/List.xml
114          0 Aug 27 2009 17:54:38 +03:00 Desktops/320x212x16
115        651 Aug 27 2009 17:54:38 +03:00 Desktops/320x212x16/List.xml
116          0 Aug 27 2009 17:54:38 +03:00 Desktops/320x212x12
117        651 Aug 27 2009 17:54:38 +03:00 Desktops/320x212x12/List.xml
118          0 Aug 27 2009 17:54:38 +03:00 autoattendant
119      94503 Aug 27 2009 17:54:40 +03:00 autoattendant/AA_SBCS_v01.aef
120      96166 Aug 27 2009 17:54:40 +03:00 autoattendant/AA_SBCS_v02.aef
121      15891 Aug 27 2009 17:54:42 +03:00 autoattendant/AA_transfer.aef
122          0 Aug 27 2009 17:54:42 +03:00 bacdprompts
123      26087 Aug 27 2009 17:54:42 +03:00 bacdprompts/app-b-acd-2.1.2.3.tcl
124      37673 Aug 27 2009 17:54:42 +03:00 bacdprompts/app-b-acd-aa-2.1.2.3.tcl
125      75650 Aug 27 2009 17:54:44 +03:00 bacdprompts/en_bacd_allagentsbusy.au
126      83291 Aug 27 2009 17:54:44 +03:00 bacdprompts/en_bacd_disconnect.au
127      63055 Aug 27 2009 17:54:46 +03:00 bacdprompts/en_bacd_enter_dest.au
128      37952 Aug 27 2009 17:54:46 +03:00 bacdprompts/en_bacd_invalidoption.au
129     496521 Aug 27 2009 17:54:48 +03:00 bacdprompts/en_bacd_music_on_hold.au
130     123446 Aug 27 2009 17:54:50 +03:00 bacdprompts/en_bacd_options_menu.au
131      42978 Aug 27 2009 17:54:50 +03:00 bacdprompts/en_bacd_welcome.au
132      34794 Aug 27 2009 17:54:52 +03:00 bacdprompts/en_bacd_xferto_operator.au
133          0 Aug 27 2009 17:54:52 +03:00 cca
134        545 Aug 27 2009 17:54:52 +03:00 cca/Key_Phoneloads.csv
135      60892 Aug 27 2009 17:54:52 +03:00 cca/sccpphoneloadstable.csv
136        385 Aug 27 2009 17:54:52 +03:00 cca/UC500_CCA_Dir_7.0.3.txt
137          0 Aug 27 2009 17:54:52 +03:00 gui
138       4118 Aug 27 2009 17:54:54 +03:00 gui/admin_user.html
139     664796 Aug 27 2009 17:54:58 +03:00 gui/admin_user.js
140       1029 Aug 27 2009 17:54:58 +03:00 gui/CiscoLogo.gif
141        657 Aug 27 2009 17:54:58 +03:00 gui/CME_GUI_README.TXT
142        953 Aug 27 2009 17:54:58 +03:00 gui/Delete.gif
143      16948 Aug 27 2009 17:55:00 +03:00 gui/dom.js
144        864 Aug 27 2009 17:55:00 +03:00 gui/downarrow.gif
145       6315 Aug 27 2009 17:55:00 +03:00 gui/ephone_admin.html
146       4558 Aug 27 2009 17:55:00 +03:00 gui/logohome.gif
147       3978 Aug 27 2009 17:55:02 +03:00 gui/normal_user.html
148      80123 Aug 27 2009 17:55:02 +03:00 gui/normal_user.js
149       1347 Aug 27 2009 17:55:02 +03:00 gui/Plus.gif
150        843 Aug 27 2009 17:55:04 +03:00 gui/sxiconad.gif
151        174 Aug 27 2009 17:55:04 +03:00 gui/Tab.gif
152       2492 Aug 27 2009 17:55:04 +03:00 gui/telephony_service.html
153        870 Aug 27 2009 17:55:04 +03:00 gui/uparrow.gif
154      10230 Aug 27 2009 17:55:06 +03:00 gui/xml-test.html
155       3493 Aug 27 2009 17:55:06 +03:00 gui/xml.template
156          0 Aug 27 2009 17:55:06 +03:00 gui/sn
157      11899 Aug 27 2009 17:55:06 +03:00 gui/sn/handshake.html
158     633459 Aug 27 2009 17:55:10 +03:00 gui/sn/handshake.swf
159          0 Aug 27 2009 17:55:10 +03:00 media
160     496521 Aug 27 2009 17:55:12 +03:00 media/music-on-hold.au
161     496521 Aug 27 2009 17:55:16 +03:00 media/music-on-hold_10db.au
162          0 Aug 27 2009 17:55:16 +03:00 ringtones
163       8160 Aug 27 2009 17:55:16 +03:00 ringtones/Analog1.raw
164       8160 Aug 27 2009 17:55:16 +03:00 ringtones/Analog2.raw
165       5280 Aug 27 2009 17:55:18 +03:00 ringtones/AreYouThere.raw
166       5040 Aug 27 2009 17:55:18 +03:00 ringtones/AreYouThereF.raw
167       8160 Aug 27 2009 17:55:18 +03:00 ringtones/Bass.raw
168      12240 Aug 27 2009 17:55:18 +03:00 ringtones/CallBack.raw
169      16040 Aug 27 2009 17:55:20 +03:00 ringtones/Chime.raw
170       8160 Aug 27 2009 17:55:20 +03:00 ringtones/Classic1.raw
171      16080 Aug 27 2009 17:55:20 +03:00 ringtones/Classic2.raw
172      10800 Aug 27 2009 17:55:20 +03:00 ringtones/ClockShop.raw
173       2823 Aug 27 2009 17:55:22 +03:00 ringtones/DistinctiveRingList.xml
174       9600 Aug 27 2009 17:55:22 +03:00 ringtones/Drums1.raw
175      13440 Aug 27 2009 17:55:22 +03:00 ringtones/Drums2.raw
176      15840 Aug 27 2009 17:55:24 +03:00 ringtones/FilmScore.raw
177      16080 Aug 27 2009 17:55:24 +03:00 ringtones/HarpSynth.raw
178       8160 Aug 27 2009 17:55:24 +03:00 ringtones/Jamaica.raw
179      16080 Aug 27 2009 17:55:24 +03:00 ringtones/KotoEffect.raw
180      12720 Aug 27 2009 17:55:26 +03:00 ringtones/MusicBox.raw
181       8160 Aug 27 2009 17:55:26 +03:00 ringtones/Piano1.raw
182      15360 Aug 27 2009 17:55:26 +03:00 ringtones/Piano2.raw
183       9360 Aug 27 2009 17:55:26 +03:00 ringtones/Pop.raw
184       7200 Aug 27 2009 17:55:28 +03:00 ringtones/Pulse1.raw
185       4000 Aug 27 2009 17:55:28 +03:00 ringtones/Ring1.raw
186       4000 Aug 27 2009 17:55:28 +03:00 ringtones/Ring2.raw
187       4000 Aug 27 2009 17:55:28 +03:00 ringtones/Ring3.raw
188       4000 Aug 27 2009 17:55:30 +03:00 ringtones/Ring4.raw
189       4000 Aug 27 2009 17:55:30 +03:00 ringtones/Ring5.raw
190       4000 Aug 27 2009 17:55:30 +03:00 ringtones/Ring6.raw
191       4000 Aug 27 2009 17:55:30 +03:00 ringtones/Ring7.raw
192       2823 Aug 27 2009 17:55:32 +03:00 ringtones/RingList.xml
193      10800 Aug 27 2009 17:55:32 +03:00 ringtones/Sax1.raw
194      14160 Aug 27 2009 17:55:32 +03:00 ringtones/Sax2.raw
195      16080 Aug 27 2009 17:55:34 +03:00 ringtones/Vibe.raw
196          0 Aug 27 2009 17:55:34 +03:00 sn
197          0 Aug 27 2009 17:55:34 +03:00 sn/tmp
198          0 Aug 27 2009 17:55:34 +03:00 sn/status
199      23043 Aug 27 2009 16:48:26 +03:00 UC520-24U-4BRI-K9-factory-7.0.3.cfg
3145728 bytes available (125038592 bytes used)
I have not done a factory reset.
./stuv &
David Harper Fri, 08/28/2009 - 02:06
This looks to me like the tftp-server config entry for the 52x phone load is missing.  Did you update the software on the UC500 using CCA or by hand?  Can you attach the output of 'show runn | i tftp' to the discussion?
Cheers,
Dave.
stuv Fri, 08/28/2009 - 02:12
TPOC-UC520#show runn | i tftp
ip inspect name SDM_MEDIUM tftp
ip tftp source-interface Loopback0
tftp-server apps11.8-2-2TR2.sbn
tftp-server apps31.8-2-2TR2.sbn
tftp-server apps41.8-2-2TR2.sbn
tftp-server apps70.8-2-2TR2.sbn
tftp-server cmterm_7936.3-3-13-0.bin
tftp-server cnu11.8-2-2TR2.sbn
tftp-server cnu31.8-2-2TR2.sbn
tftp-server cnu41.8-2-2TR2.sbn
tftp-server cnu70.8-2-2TR2.sbn
tftp-server CP7902080002SCCP060817A.sbin
tftp-server cvm11sccp.8-2-2TR2.sbn
tftp-server cvm31sccp.8-2-2TR2.sbn
tftp-server cvm41sccp.8-2-2TR2.sbn
tftp-server cvm70sccp.8-2-2TR2.sbn
tftp-server dsp11.8-2-2TR2.sbn
tftp-server dsp31.8-2-2TR2.sbn
tftp-server dsp41.8-2-2TR2.sbn
tftp-server dsp70.8-2-2TR2.sbn
tftp-server jar11sccp.8-2-2TR2.sbn
tftp-server jar31sccp.8-2-2TR2.sbn
tftp-server jar41sccp.8-2-2TR2.sbn
tftp-server jar70sccp.8-2-2TR2.sbn
tftp-server P00308000500.bin
tftp-server P00308000500.loads
tftp-server P00308000500.sb2
tftp-server P00308000500.sbn
tftp-server SCCP11.8-2-2SR2S.loads
tftp-server SCCP31.8-2-2SR2S.loads
tftp-server SCCP41.8-2-2SR2S.loads
tftp-server SCCP70.8-2-2SR2S.loads
tftp-server flash:SCCP42.8-3-2S.loads
tftp-server flash:SCCP45.8-3-2S.loads
tftp-server flash:SCCP75.8-3-2S.loads
tftp-server flash:apps42.8-3-1-22.sbn
tftp-server flash:apps45.8-3-1-22.sbn
tftp-server flash:apps75.8-3-1-22.sbn
tftp-server flash:cnu42.8-3-1-22.sbn
tftp-server flash:cnu45.8-3-1-22.sbn
tftp-server flash:cnu75.8-3-1-22.sbn
tftp-server flash:cvm42sccp.8-3-1-22.sbn
tftp-server flash:cvm45sccp.8-3-1-22.sbn
tftp-server flash:cvm75sccp.8-3-1-22.sbn
tftp-server flash:dsp42.8-3-1-22.sbn
tftp-server flash:dsp45.8-3-1-22.sbn
tftp-server flash:dsp75.8-3-1-22.sbn
tftp-server flash:jar42sccp.8-3-1-22.sbn
tftp-server flash:jar45sccp.8-3-1-22.sbn
tftp-server flash:jar75sccp.8-3-1-22.sbn
tftp-server flash:APPS-1.0.4.SBN
tftp-server flash:GUI-1.0.4.SBN
tftp-server flash:SYS-1.0.4.SBN
tftp-server flash:TNUX-1.0.4.SBN
tftp-server flash:TNUXR-1.0.4.SBN
tftp-server flash:WLAN-1.0.4.SBN
tftp-server flash:cp524g-08-01-07.bin
tftp-server flash:apps37sccp.1-1-1-1.bin
tftp-server flash:spa525g-7-1-3.bin
tftp-server flash:cp524g-08-01-13.bin
tftp-server flash:cnu75.8-3-4-16.sbn
tftp-server flash:SCCP75.8-3-5S.loads
tftp-server flash:cvm75sccp.8-3-4-16.sbn
tftp-server flash:jar75sccp.8-3-4-16.sbn
tftp-server flash:dsp75.8-3-4-16.sbn
tftp-server flash:apps75.8-3-4-16.sbn
tftp-server flash:dsp70.8-3-4-16.sbn
tftp-server flash:cnu70.8-3-4-16.sbn
tftp-server flash:SCCP70.8-3-5S.loads
tftp-server flash:apps70.8-3-4-16.sbn
tftp-server flash:jar70sccp.8-3-4-16.sbn
tftp-server flash:cvm70sccp.8-3-4-16.sbn
tftp-server flash:dsp45.8-3-4-16.sbn
tftp-server flash:cnu45.8-3-4-16.sbn
tftp-server flash:jar45sccp.8-3-4-16.sbn
tftp-server flash:SCCP45.8-3-5S.loads
tftp-server flash:cvm45sccp.8-3-4-16.sbn
tftp-server flash:apps45.8-3-4-16.sbn
tftp-server flash:dsp42.8-3-4-16.sbn
tftp-server flash:cvm42sccp.8-3-4-16.sbn
tftp-server flash:cnu42.8-3-4-16.sbn
tftp-server flash:apps42.8-3-4-16.sbn
tftp-server flash:jar42sccp.8-3-4-16.sbn
tftp-server flash:SCCP42.8-3-5S.loads
tftp-server flash:dsp41.8-3-4-16.sbn
tftp-server flash:SCCP41.8-3-5S.loads
tftp-server flash:cnu41.8-3-4-16.sbn
tftp-server flash:cvm41sccp.8-3-4-16.sbn
tftp-server flash:jar41sccp.8-3-4-16.sbn
tftp-server flash:apps41.8-3-4-16.sbn
tftp-server flash:cmterm_7936.3-3-15-0.bin
tftp-server flash:cvm31sccp.8-3-4-16.sbn
tftp-server flash:apps31.8-3-4-16.sbn
tftp-server flash:cnu31.8-3-4-16.sbn
tftp-server flash:jar31sccp.8-3-4-16.sbn
tftp-server flash:dsp31.8-3-4-16.sbn
tftp-server flash:SCCP31.8-3-5S.loads
tftp-server flash:cnu11.8-3-4-16.sbn
tftp-server flash:apps11.8-3-4-16.sbn
tftp-server flash:jar11sccp.8-3-4-16.sbn
tftp-server flash:SCCP11.8-3-5S.loads
tftp-server flash:cvm11sccp.8-3-4-16.sbn
tftp-server flash:dsp11.8-3-4-16.sbn
tftp-server flash:/phones/7921/GUI-1.2.1.SBN alias GUI-1.2.1.SBN
tftp-server flash:/phones/7921/TNUX-1.2.1.SBN alias TNUX-1.2.1.SBN
tftp-server flash:/phones/7921/SYS-1.2.1.SBN alias SYS-1.2.1.SBN
tftp-server flash:/phones/7921/APPS-1.2.1.SBN alias APPS-1.2.1.SBN
tftp-server flash:/phones/7921/CP7921G-1.2.1.LOADS alias CP7921G-1.2.1.LOADS
tftp-server flash:/phones/7921/WLAN-1.2.1.SBN alias WLAN-1.2.1.SBN
tftp-server flash:/phones/7921/TNUXR-1.2.1.SBN alias TNUXR-1.2.1.SBN
tftp-server flash:/phones/7925/GUIH-1.3.1.SBN alias GUIH-1.3.1.SBN
tftp-server flash:/phones/7925/TNUXH-1.3.1.SBN alias TNUXH-1.3.1.SBN
tftp-server flash:/phones/7925/CP7925G-1.3.1.LOADS alias CP7925G-1.3.1.LOADS
tftp-server flash:/phones/7925/APPSH-1.3.1.SBN alias APPSH-1.3.1.SBN
tftp-server flash:/phones/7925/WLANH-1.3.1.SBN alias WLANH-1.3.1.SBN
tftp-server flash:/phones/7925/SYSH-1.3.1.SBN alias SYSH-1.3.1.SBN
tftp-server flash:/phones/7914/S00105000300.sbn alias S00105000300.sbn
tftp-server flash:/phones/7975/term75.default.loads alias term75.default.loads
tftp-server flash:/phones/7970_7971/term71.default.loads alias term71.default.loads
tftp-server flash:/phones/7970_7971/term70.default.loads alias term70.default.loads
tftp-server flash:/phones/7945_7965/term45.default.loads alias term45.default.loads
tftp-server flash:/phones/7945_7965/term65.default.loads alias term65.default.loads
tftp-server flash:/phones/7942_7962/term62.default.loads alias term62.default.loads
tftp-server flash:/phones/7942_7962/term42.default.loads alias term42.default.loads
tftp-server flash:/phones/7941_7961/term41.default.loads alias term41.default.loads
tftp-server flash:/phones/7941_7961/term61.default.loads alias term61.default.loads
tftp-server flash:/phones/7931/term31.default.loads alias term31.default.loads
tftp-server flash:/phones/7906_7911/term06.default.loads alias term06.default.loads
tftp-server flash:/phones/7906_7911/term11.default.loads alias term11.default.loads
tftp-server flash:Desktops/CampusNight.png
tftp-server flash:Desktops/CiscoFountain.png
tftp-server flash:Desktops/CiscoLogo.png
tftp-server flash:Desktops/Fountain.png
tftp-server flash:Desktops/MorroRock.png
tftp-server flash:Desktops/NantucketFlowers.png
tftp-server flash:Desktops/TN-CampusNight.png
tftp-server flash:Desktops/TN-CiscoFountain.png
tftp-server flash:Desktops/TN-CiscoLogo.png
tftp-server flash:Desktops/TN-Fountain.png
tftp-server flash:Desktops/TN-MorroRock.png
tftp-server flash:Desktops/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:autoattendant/AA_SBCS_v01.aef
tftp-server flash:autoattendant/AA_SBCS_v02.aef
tftp-server flash:autoattendant/AA_transfer.aef
tftp-server flash:bacdprompts/app-b-acd-2.1.2.3.tcl
tftp-server flash:bacdprompts/app-b-acd-aa-2.1.2.3.tcl
tftp-server flash:bacdprompts/en_bacd_allagentsbusy.au
tftp-server flash:bacdprompts/en_bacd_disconnect.au
tftp-server flash:bacdprompts/en_bacd_enter_dest.au
tftp-server flash:bacdprompts/en_bacd_invalidoption.au
tftp-server flash:bacdprompts/en_bacd_music_on_hold.au
tftp-server flash:bacdprompts/en_bacd_options_menu.au
tftp-server flash:bacdprompts/en_bacd_welcome.au
tftp-server flash:bacdprompts/en_bacd_xferto_operator.au
tftp-server flash:cca/Key_Phoneloads.csv
tftp-server flash:cca/sccpphoneloadstable.csv
tftp-server flash:cca/UC500_CCA_Dir_7.0.3.txt
tftp-server flash:gui/admin_user.html
tftp-server flash:gui/admin_user.js
tftp-server flash:gui/CiscoLogo.gif
tftp-server flash:gui/CME_GUI_README.TXT
tftp-server flash:gui/Delete.gif
tftp-server flash:gui/dom.js
tftp-server flash:gui/downarrow.gif
tftp-server flash:gui/ephone_admin.html
tftp-server flash:gui/logohome.gif
tftp-server flash:gui/normal_user.html
tftp-server flash:gui/normal_user.js
tftp-server flash:gui/Plus.gif
tftp-server flash:gui/sxiconad.gif
tftp-server flash:gui/Tab.gif
tftp-server flash:gui/telephony_service.html
tftp-server flash:gui/uparrow.gif
tftp-server flash:gui/xml-test.html
tftp-server flash:gui/xml.template
tftp-server flash:gui/sn/handshake.html
tftp-server flash:gui/sn/handshake.swf
tftp-server flash:media/music-on-hold.au
tftp-server flash:media/music-on-hold_10db.au
tftp-server flash:ringtones/Analog1.raw
tftp-server flash:ringtones/Analog2.raw
tftp-server flash:ringtones/AreYouThere.raw
tftp-server flash:ringtones/AreYouThereF.raw
tftp-server flash:ringtones/Bass.raw
tftp-server flash:ringtones/CallBack.raw
tftp-server flash:ringtones/Chime.raw
tftp-server flash:ringtones/Classic1.raw
tftp-server flash:ringtones/Classic2.raw
tftp-server flash:ringtones/ClockShop.raw
tftp-server flash:ringtones/DistinctiveRingList.xml
tftp-server flash:ringtones/Drums1.raw
tftp-server flash:ringtones/Drums2.raw
tftp-server flash:ringtones/FilmScore.raw
tftp-server flash:ringtones/HarpSynth.raw
tftp-server flash:ringtones/Jamaica.raw
tftp-server flash:ringtones/KotoEffect.raw
tftp-server flash:ringtones/MusicBox.raw
tftp-server flash:ringtones/Piano1.raw
tftp-server flash:ringtones/Piano2.raw
tftp-server flash:ringtones/Pop.raw
tftp-server flash:ringtones/Pulse1.raw
tftp-server flash:ringtones/Ring1.raw
tftp-server flash:ringtones/Ring2.raw
tftp-server flash:ringtones/Ring3.raw
tftp-server flash:ringtones/Ring4.raw
tftp-server flash:ringtones/Ring5.raw
tftp-server flash:ringtones/Ring6.raw
tftp-server flash:ringtones/Ring7.raw
tftp-server flash:ringtones/RingList.xml
tftp-server flash:ringtones/Sax1.raw
tftp-server flash:ringtones/Sax2.raw
tftp-server flash:ringtones/Vibe.raw
tftp-server flash:vlan.dat
tftp-server flash:phones/521_524/cp524g-8-1-16b.bin
David Harper Fri, 08/28/2009 - 02:20
Try configuring 'tftp-server flash:phones/521_524/cp524g-8-1-16b.bin alias cp524g-8-1-16b.bin'.  The alias is necessary because the phone does not know anything about the directory structure on the flash card, so is not asking for phones/521_524/cp524g-8-1-16b.bin.
Cheers,
Dave.
stuv Mon, 08/31/2009 - 23:19
Thank you very much guys, problems solved!!!!!!!!
-  All phones are registering correctly on poe switch (IOS upgrade on switch resolved this)
- All phones getting the new phone load (I did upload the phone load correctly, but did not apply the alias commnd, this is what was wrong)
- With the  new phone load, the PC switchport is enabled, I am sending this post by my laptop connected to the PC port.
Once again, thanks for the help.  I hope this information is helpful to others.
./stuv &
eljaouhari04 Mon, 10/12/2009 - 09:52
i have the same problem
i can't connect UC500 with cisco IP Phone 521S
and when i maked "show runn | i tftp ",i don't found  "tftp-server flash:phones/521_524/cp 524g-8-1-16b.bin"
please help me
Steven DiStefano Mon, 10/12/2009 - 09:55
Hi,Use CCA 2.1 Phone Load manager to add phone load support to your system.  You only have to point it to the bundle zip you are running and it does an analysis of the phone loads and presents the ones to you that arent on your system yet and creates all the configuration for you.  No CLI.  Easies way.
Steve
stuv Tue, 10/13/2009 - 00:09
Phone loads need to be 8.1.16(b)
sh ephone phone-load
will show you this.
Also you need to set an alias because tftp-server cannot go into tree on flash
good luck and happy hunting
./stuv &
Marcos Hernandez Wed, 08/26/2009 - 07:18
Hi Stuv,
I am sorry you are having these many issues. The problem with the disabled switch port we have seen before, You need to ensure that you are using the latest PHONE LOAD as well, not just the latest IOS. What are your current phone load and IOS versions?
The latest bundle can be found on:
https://supportforums.cisco.com/docs/DOC-9829
This contains all the latest phone loads. You can use CCA 2.0.1 to easily upgrade the system:
https://www.myciscocommunity.com/docs/DOC-7157
Also, on your 2960, please make sure that your voice and data VLANs are 100 and 1 respectively. CCA will not recognize the Catalyst 2900 as supported, so you will have to resort to CLI to configure it (which obviously you have already done).
Let us know,
Marcos
