VLAN with diferent gateway.
Aug 26th, 2009
I have three VLAN's configured in a C3560 Software (C3560-IPBASEK9-M), data, voice and WAN.
The WAN VLAN has two routers connected, I need to know how I can send voice traffic by one router and data traffic by another router, do you know how I can do it?.
Can I do it with this IOS?.
luisveraza Wed, 08/26/2009 - 07:58
Ok, thank you.
I got the IP services software, do you have the procedure for updating it ?.
Thank you !.
Jon Marshall Wed, 08/26/2009 - 08:09
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Luis
If you are running IP Services on your 3560 then it already supports PBR. You will however need to enable the SDM routing template ie.
3560(config)# sdm routing prefer
Jon
luisveraza Wed, 08/26/2009 - 08:17
No, I have: Image Name c3560-ipbasek9-mz.122-40.SE.bin.
But I got: c3560-ipservicesk9-mz.122-40.SE.bin
So I need to know how to upgrade it ?.
luisveraza Wed, 08/26/2009 - 09:39
Thank you by your support.
The procedure shows the next command:
archive download-sw /allow-feature-upgrade /overwrite /reload tftp:[[//location]/directory]/image-name.tar
I have an Bin file, I don't have the tar file.
Do you know If I can use this command with this Bin file?.
Thank you, best regards.
luisveraza Wed, 08/26/2009 - 08:18
I found it:
¨¨¨The Cisco Catalyst 3560 is available with either the IP Base or IP Services software images. The IP Base software includes advanced QoS, rate-limiting, ACLs, and basic routing and IPv6 functionality.
The IP Services software provides a richer set of enterprise-class features, including advanced hardware-based IP unicast and IP Multicast routing as well as policy-based routing (PBR)¨¨¨.
So, I need to upgrade to IP Services software.
